  • Guests: 62
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Methods for estimating secondary's wire length on spool
Tonic
Fri Jul 04 2008, 11:28AM Print
Let's say you have a spool of wire, you know wire's diameter and mass of all wire. What do you do to measure, at least roughly, its length?
GluD
Fri Jul 04 2008, 11:31AM
GluD Registered Member #1221 Joined: Wed Jan 09 2008, 06:17PM
If i understood the question correctly, this site should help:
Tonic
Fri Jul 04 2008, 12:16PM
No, that's not :) What I'm trying to learn is measuring the wire length on spool having only wire's diameter and mass of spool (without form).
Fraggle
Fri Jul 04 2008, 12:22PM
Fraggle Registered Member #1526 Joined: Mon Jun 09 2008, 12:56AM
length=(mass of reel)(area of x-section)/(density of Copper)
ignoring the mass of the bobbin itself.
GluD
Fri Jul 04 2008, 12:52PM
ah sorry >_<
Tonic
Fri Jul 04 2008, 01:56PM
Fraggle wrote ...
That's a wrong equation, because you get m^5 as length unit. The proper equation would be length = (mass of reel)/[ (area of x-section)*(density of copper) ], there you get m as unit. That was a metod I've used, but I have no idea how accurate it is. With this, I calculated that my spool with 0.45kg of 0.35mm wire has 230m of wire. What safety margin can I use? 220, 210 or 200m?
Fraggle
Fri Jul 04 2008, 03:00PM
Dammit, I hate trying to do these things in my head with ascii notation :o)
Anyways, just use the uncertainties of your mass and diameter to work out the error in the usual way. I`d bet that you`ve only got two figures by the time the errors caused by the insulation and reel add up.
GeordieBoy
Fri Jul 04 2008, 10:14PM
I would measure the DC resistance at room temperature if you can get to both ends of the wire. Then calculate an estimate of the number of metres on the drum.
Sat Jul 05 2008, 03:08AM
Tonic wrote ...
Just get some wire specs.
Here is chart showing wire gauge (which you can determine by diameter) and feet per lb of wire.
For magnet wire (which includes an enamel), there are different charts online.
