  • Guests: 41
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
Carl A. Willis (45)
10/03 TwirlyWhirly555 (33)
10/04 Michael W. (36)
10/05 GhostlyFigures (36)
Big 6 inch coil.
Wed Jul 02 2008, 06:22AM Print
Well i have started a new coil, 6 inch in diameter and 30 inches long. I will be using rogers 2 mot and doubler setup, i would use 4 mots but i only have 100amps service :P.
My 6 inch coil being wound.
The mmc, made of 32 CDE .68uf 1600vdc caps. Will be tapped for about 40nf to 50 nf.
The twin mot circuit with doubler for power supply.
Me after all that work on the coil, after a hot day :P
Shaun
Wed Jul 02 2008, 03:04PM
What kind of MOTs do you have that four of them would draw over 100A?
Dr. SSTC
Wed Jul 02 2008, 11:18PM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
lol how much power do you want to be consuming i plann on making a 1kw coil in the next months as i found a really neat 1000watt choke under my house last year, so i guess i could have 4 mots in parralel which would mean 8 kv at an alright current
Thu Jul 03 2008, 12:12AM
Shaun wrote ...
Lol i am just saying, it might draw up to like 60 amps when running full bps and i dont have the wiring to do that and if i had to much stuff running in the house, i would trip the breaker. I am not willing to take that chance, and get everyone PO'ed.
Wirenut
Thu Jul 03 2008, 03:55AM
Wirenut Registered Member #141 Joined: Sat Feb 11 2006, 01:14PM
<-----My MOT 6-pack drew <100 amps unballasted into a dead short, drawing an arc. More like 30-40A max with the coil running at 700bps with a .15uF cap. There's no way you'll trip a 100A main breaker with 2 mots.
Thu Jul 03 2008, 04:01AM
Wirenut wrote ...
Really? I have tripped a 15 amps breaker into a short with one mot so i figured that. Thanks for letting me know though. But i want to use this supply so i dont have to have to have a really powerful cap. It would take like 60nf or something, at 8kv ac, mine will have about half the punishment since it is dc. And my coil will need to be bigger to harvest the full power of the mot's...i think...
Dr. SSTC
Thu Jul 03 2008, 04:06AM
arc starter so are you gonna use ac or dc for the capacitor charging
Thu Jul 03 2008, 11:44AM
Wirenut wrote ...
Just want to say here that the european 230/240V MOTs will draw around 20A when shorted! This means that a 6-pack would draw 120A, which translates to 240A from 120V for the same VA! I know 60Hz MOTs draw a bit less but I think not much less.
I think people are often "measuring" their current by their breaker rating, but that's bad because the breaker will give twice the amps for half a minute maybe.
Thu Jul 03 2008, 09:23PM
Well i am planning on using 240 volts for the mot's to cut down on current and i can get more wattage from 240 volts because i have 30 amps max on 120 volts as well as 240. I am using dc, straight from the doubler.
Mike
Thu Jul 03 2008, 10:38PM
Please read up on safety, especially when using mots on 240volts.. they are almost surely lethal at that level...
