  • Guests: 57
GimpyJoe (36)
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Random Capacitors for sale
Bust_A_Cap
Sun Jun 29 2008, 03:56PM Print
Bust_A_Cap Registered Member #1561 Joined: Mon Jun 23 2008, 07:58PM
I've also got a couple of random capacitors that I feel could go to good use by someone in the 4HV community so if your interested in any of the below just pm me with an offer, and I'll get back to you as soon as possible.
As far as the type of capacitor that these are i'm not real sure, but if you want more information that what is given I can give you all the numbers off the side of the cap and you can see if you can find some data sheets online.
10 Nippon Chemi-Con 63V 68000uF
1 Nippon Chemi-Con 400V 2200uF
1 Nippon Chemi-Con 450V 1800uF
1 Nippon Chemi-Con 400V 2700uF
1 Nippon Chemi-Con 400V 3900uF
1 GE 370VAC 35uF
6 Maxwell PowerCache 2.5V 2700F Ultra Capacitors
Also I have 133 of these smaller capacitors. Rated at 450V and 470uF. I figured someone could use these to make a REALLY nice hand held multi stage coilgun.
EEYORE
Sun Jun 29 2008, 04:26PM
How much for the ultra caps?
Matt
Linas
Sun Jun 29 2008, 05:51PM
can say parameters tall and diameter (i need 4cm diameter, and 7cm tall)
Bust_A_Cap
Sun Jun 29 2008, 09:40PM
Linas; I'll get back to you on the specifications of the size of the caps.
Also I'd like to add that I have 3 Ness Ultracapacitors rated at 2.7V at 3500F;
