  • Guests: 55
01/13 si2030 (62)
Universal driver
Sun Mar 19 2006, 07:21PM Print
After reading the high voltage threads, I wanted to build a kind of universal driver for flybacks and ignition coil too. As usually, it is structured around an astable chip. I found the schema on a german site. The power is much lower than in a ZVS driver, but still is a nice toy to play with...
http://www.geocities.com/romtcb/universaldriver.html
Enjoy
Marko
Sun Mar 19 2006, 07:42PM
I think its very good idea to replace bipolar transistor gate drive with driver IC or power transistors in darlington, in my flyback driver
I had problems with overheating of gate drivers, for mosfet that was actually BDT driver!
On low duty cycles it works nice but f I go for 50% and more they overheat and blow in couple of minutes.
Sun Mar 19 2006, 09:40PM
meh, nothing new under the sun tongue
Actually, if well designed, these flyback topology (single power switch) drivers work very efficiently at low powers. (yes, flybacks got their name from the topology they are being driven with, not the driver from the transformer).
smile
Marko
Sun Mar 19 2006, 10:11PM
For now it works too good (5cm spark with only 50W) and it can stand a lot more than current 28V.
I fried foolishly some HV transistors, overvolting B-E with bad BDT so I cant make it running at 300V as I intended.
Now I use my own BDT with protection diodes and even without them it doesnt generate more than 2V in kickback.
As I said most of problems are with driver, gatedrive of mosfet suffers great stresses and I cant help it for now dead
Sun Mar 19 2006, 10:18PM
For me, a 494 driving directly a power mosfet gate with a help of pull-up resistor works well. (crappy 8kvac flyback, 30kV out with 20W in, drives a big plasma globe really nicely).
In that schematic posted by Vasil, there's a cap. across the transistor which I have found really helps keeping it cool.
Simon
Sun Mar 19 2006, 11:04PM
My universal driver is far simpler. It's an MJ10012 driven directly from a tunable 555.
Of course, to get the most out of a transformer, the all-rounder approach won't work but having a driver for trying out any transformer you have is handy.
Marko
Sun Mar 19 2006, 11:12PM
Im wondering how don't you fry NE555, bipolar transistors need lots more current than it can give.
At least small darlington would help.
For real power base drive transformer must be used, it lowers greatly needed drive current, drives base on low voltage/high current for minimum dissipation and helps in isolation if circuit operaes at high voltages...
Mon Mar 20 2006, 11:27AM
I LIKE the 555 with a MOSFET or IGBT, very reliable/dependable.
I also use HOT BJTs for very high voltages. (with a buffer/driver)
I never find the driving to be a problem,
it's the inductance snubbing that bugs me
and for this the easiest/safest is to use an avalanche-rated switch/IGBT etc.
Since your BUP307 is avalanch rated - no problem (except heat)
Others should be aware that a non-avalanche rated device may die in this circuit
as there's no other proper snubbing.
The capacitor across the transistor will 'snub' the spikes
but it would be better with 10 to 100 ohms in series
as it is discharged directly into the transistor each time the transistor turns on
giving unneccessary current spikes.
Mon Mar 20 2006, 01:01PM
The resistor would not slow down the voltage droping across the drain- source?
I can try though...
Mon Mar 20 2006, 01:06PM
I found that without the cap, the driver would draw 2-3x the power when not drawing an arc, as opposed to with the capacitor and properly tuned frequency, the "idle" power is much lower, but the output voltage is higher and arcs are a bit hotter. (and the fet stays cooler as mentioned); maybe the cap resonates with the flyback primary???
confused
