  • Guests: 40
Experimental lightning bolt generator
EHT
Fri Jun 27 2008, 11:45PM Print
EHT Registered Member #1564 Joined: Wed Jun 25 2008, 05:09PM
I have this idea for a new type of high voltage generator which involves a car pressure washer. I have attached a quick sketch of the concept so you get an idea of the setup.
A pvc pipe is driven into the ground, lets say two meters long and to the top of you secure the lance from a pressure washer.
The lance is adjusted so that it produces a fine mist which fan-out projecting a fine mist upwards into the air.
At the top of the lance a conductive washer is secured so that the jet flows through the hole in the centre before fanning out.
The washer is connected to a negative dc EHT supply (say 100kv).
The fine water mist produced is therefore highly negatively charged. As the negative charge build-up it starts to cause the ground under the vapour cloud to become increasingly positively charged until BANG, an artificially generated lightning bolt hits the ground rod.
I haven’t tried it yet but my understanding tells me it should work, would like to know what you guys think?
1214610326 1564 FT0 Lightning Generator
Myke
Fri Jun 27 2008, 11:51PM
I think for the voltage to be high enough to jump from charged water droplets, it can jump from the charger to the ground easier. Also unless the water had no salts or stuff, it would conduct electricity...
Is this right?
EHT
Sat Jun 28 2008, 12:09AM
Ok fairly easy to solve, make a battery powered EHT and secure it to the top of the pvc pipe. You could put the tap water through a filter to remove the salts and chlorine.
Antonio
Sat Jun 28 2008, 12:52AM
If the ring is negative, the water will come out positive, due to the induction on the tip of the jet. Most probably the water will just be attracted to everything nearby, dropping to the ground quite quickly.
Sat Jun 28 2008, 06:05AM
My thoughts also.
Some industrial paint sprayers electrically charge the paint droplets which zoom to any grounded conductor.
(this allows the paint to coat all around the object when sprayed from just one direction)
EHT
Sat Jun 28 2008, 10:03AM
This is an outdoors experiment and would be conducted in an open area with flat ground, the nearest nearby object for the charged droplets to ground to would be the ground itself which depending on the hight of the pvc pipe is could be some distance.
Its a high pressure washer which means the atomised water droplets exit the nozzle with high velocity in an upwards direction, yes they would be attracted to the ground but the electrostatic charge is not great enough to overcome the velocity at which they are projected upwards. I assume a mushroom shaped body of atomised water would develop above the pvc pipe.
On its finest setting the average pressure produces a large volume of atomised water in just a few seconds so this must equate to a large charge build-up.
I set my pressure washer to its finest setting and directed it upwards, The atomised water droplets produced are small enough and light enough to remain in the air for some time assuming its not a windy day.
Bjørn
Sat Jun 28 2008, 11:54AM
Kelvin did this 140 years ago so it is not very new. You will get wet and that is the most interesting thing that will happen, that is if no one gets electrocuted.
EHT
Sat Jun 28 2008, 12:16PM
Dr Alban, Kelvins device was very different, I have actually made one in the past, was interesting to see how a large charge can be generated by a few drops.
Is this the device your referring to?
Antonio
Sat Jun 28 2008, 04:36PM
A similar idea was Armstrong's hydroelectric machine, where an insulated boiler was charged to high voltage by steam jets flowing from it:
