  • Guests: 47
Help with capacitor charging/triggering circuit.
nabiul
Thu Jun 26 2008, 03:39PM Print
nabiul Registered Member #1558 Joined: Sun Jun 22 2008, 08:22PM
Circuits for supplies can be found all over the net but I haven't seen any for charging a capacitor and then waiting for discharge, well besides on sam's faq, but those aren't what I need.
Using my vague memory of electronics from two years ago I came up with this for a coil gun circuit, please advise on what needs to be fixed. I'm not so concerned about any values at this point.
Myke
Thu Jun 26 2008, 11:37PM
For a charging circuit, can't you just use the same circuit for a disposable camera inverter?
1214523452 540 FT48419 Untitled
nabiul
Fri Jun 27 2008, 01:06AM
That requires a transformer with taps though, I have a regular transformer with single primary/secondary. And im not so worried about the power part, like i put in my picture, i have ac current coming in from a 'source' , the rest of the circuit deals with charging the caps then stopping the flow of electricity once they are charged and turning on an led to indicate that they are charged, then triggering it when the switch is pressed.
I'm not sure how to get the circuit to stop charging the caps once they are full, I posted what I think would work, but I don't remember anything about electronics. I mean c'mon all you hv guys out there can't be using camera units for charging and triggering.
aonomus
Fri Jun 27 2008, 02:48AM
If you want a simple camera board based charger, for a transformer without a feedback tap, this one seems to be pretty compact.
nabiul
Fri Jun 27 2008, 03:35AM
already tried, doesn't work unless you have the exact components. And that still doesn't help since its just a transformer which I already said that I don't need. Im talking about what the transformer supplies power to >.>.
