  • Guests: 54
New dual MOT SGTC
Wed Jun 25 2008, 08:56PM Print
I built these days another dual MOT for a friend (he needs it for a presentation or maibe to impress some other guys, who knows). I dont have the time to set a web page, but I made a quick movie presentation (sort of...) and some "action" movies.
The power source is just two MOTs in serie (4-4.5 kV output), inductive ballasted on the low voltage side. I still believe that it is the cheapest solution for the eastern Europe where the NSTs are still rare. They give enough power for a healthy streamer and if they are well ballasted they can get some more voltage input (from a variac) without saturation (just more voltage and lower current in the same power area). The gap is not set very wide (to mantain the breakrate at resonable high level), so the streamer is not the longest possible, but is still very good for a presentation. I wound a bit longer secondary to prevent the strikes to the strikerail, allowing the full lenght for the streamers. Because the low kV input the primary cap cost is very low.
The presentation movie HERE
220 V from mains, multiple streamer output
MOVIE
250 V from variac, more like a single streamer output
MOVIE
Enjoy
Ultra7
Thu Jun 26 2008, 02:55AM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
Very cool, Vasil.
You said the ballasts were from Mercury vapor lamps?
Thu Jun 26 2008, 05:13AM
Yep. 250 watts each, two ballast coils in parallel, connected in serie with the MOTs input.
Dr. H.
Thu Jun 26 2008, 05:20AM
Very nice Vasil smile
aren't those caps heating ? If not you can increase the power ...
CHeers Dr. H.
Thu Jun 26 2008, 05:34AM
Thanx. The caps are cool, they are overrated at 4 x input voltage and 3 strings in parallel (12.5 nF per string) distribute the current very well). If you look at the presentation movie, you notice that I leaved an empty place for a possible one more ballast coil for more power. But I think that it is enough for a presentation coil.
Alexandre
Thu Jun 26 2008, 08:31PM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
cool coil
