  • Guests: 35
michi's TL494 fullbridge flyback driver: need specs on diodes.
termination
Wed Jun 25 2008, 12:18PM Print
termination Registered Member #1559 Joined: Mon Jun 23 2008, 10:17AM
Hi all,
I'm kinda new to this forum, but allready have a good question (i think).
I'm trying to find out what types of diodes I should use for Michi's fullbridge flyback driver.
The schematic says D2 and D5 should be 10A diodes at least, and the MOSFET's should be 50V 10A each, but it doesn't say anything about the other diodes.
So my question is: has anyone built this driver (with or without audio modulation) and if so, do you have the numbers of the diodes and MOSFET's used? It would really help me.
schematic:
Fullbridge
mod edit: oversized image: original here Link2
Kind regards,
Thom.
EDIT: found my good old friend, the IRF740. specs: 10A/ 400V/ 0.550 Ohm/ N-Channel Power MOSFET is that a good one?
Wed Jun 25 2008, 12:40PM
I designed the original circuit this is based on.
Those MOSFETs will work fine, but since the supply voltage of this circuit is limited to about 30-50V by other factors, their 400V rating is wasted. You could use lower voltage FETs and get more efficient operation due to their lower Rds(on).
The diodes that aren't high current could be UF4002 or whatever. The high current ones need to be fast recovery, and the same current rating as your MOSFETs.
termination
Wed Jun 25 2008, 12:59PM
Hmm i see.
Something like a BUZ10 (N-CHANNEL 50V - 0.06 OHM - 23A TO-220 STRIPFET POWER MOSFET) would be better than.
Do the diodes need to be shottky diodes? (don't know the real difference between shottky and normal, so if anyone could explain that)
EDIT: the SBM1040 shottky diode seems fine. (40V 10A, see: here )
Marko
Wed Jun 25 2008, 04:07PM
Looking at this again, the schematic appears wrong. There seems to be no way for pins 9 and 10 to ever get pulled down to ground, or, I'm missing some secret part of the TL494?
Second what I I don't understand is, why go stepping the mains voltage down to 30V by a transformer only to step it up back into HV by flyback transformer.
Also, the choice of Tl494 as controller seems poor to me as it only has transistor outputs with open collectors/emitters.
For driving mosfets, especially through a GDT, I always proffered to use SG3525, GDT and a halfbridge. (No need for fullbridges at power levels flyback transformers can handle).
You should be able to get SG3525 anywhere you can get TL494. I will post you a schematic if you want.
If you can get IR2152 or similar IC, you don't even need a GDT, only few extra components. They are available in digikey.
*marko wonders about very oversize picture but ignores it
termination
Wed Jun 25 2008, 05:53PM
Yeah, sorry about the picture size.
OK. I got all parts (diodes and MOSFET's worked out well)
I'm using MBR1645 diodes and BUZ11 MOSFET's.
only problem is that I can't get my hands on a TC4429.
Does anyone have a good replacement for it?
I looked at the MAX626 adn it's datasheet, but can't find any maximum ratings for current.
also a little sidenote on internet orders. I live in the Netherlands, so ordering from america or japan is a little bit too expensive.
Wed Jun 25 2008, 06:00PM
Marko wrote ...
Yes you are cheesey The output has some pull-down built in which is sufficient to drive a small FET. However some "chinese" versions of the chip are missing this pulldown.
termination
Thu Jun 26 2008, 09:19AM
*bump*
New problem!
I looked at the MAX626 and it's datasheet, but can't find any maximum ratings for current.
Dr. SSTC
Sun Jul 06 2008, 07:17AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
termination wrote ...
Hmm i see.
Schotty diodes have a much lower voltage drop and a higher
effiency
