  • Guests: 35
Soda bottle SSTC
cjk2
Sun Mar 19 2006, 01:34AM Print
I wanted to try making a small high frequency coil using a Royer style driver so I decided to use a mini Dr. Pepper bottle as a start. I used some 30awg magnet wire to wind maybe 200 turns arround the center of the bottle. I cleaned the bottle with lighter fluid before winding to remove any residue from the sticker that was on the bottle. I then made a 2 + 2 turn primary to connect to my old ZVS flyback driver. I have no idea what frequency it runs at but it must be very high. I have gone up to 50vac unfiltered in to the driver and it gives about .5" corona on the output wire. For about an hour of work, this is a really cool coil and I hope to build a better royer driver for it soon. Perhaps if I get a real ground for it it will work better..
1142732006 51 FT0 Sbc1
1142732006 51 FT0 Sbc2
Self Defenestrate
Sun Mar 19 2006, 04:20AM
Self Defenestrate Registered Member #87 Joined: Thu Feb 09 2006, 01:36PM
Now put the driver circuitry inside the bottle, and add a tilt switch to turn it on when it's tipped. Glass of Corona anyone?
cjk2
Sun Mar 19 2006, 04:25AM
Lol great idea! I was actually thinking of building it all in the bottle. Maybe I will if I ever have the time.
ZakWolf
Fri Nov 05 2010, 02:51AM
If i use a high power ZVS flyback driver will i get good results?
Whats the difference between the two flyback drivers?
Adam Munich
Fri Nov 05 2010, 04:02AM
I have some 28AWG wire that needs a home. I may try this...
ZakWolf
Fri Nov 05 2010, 04:38AM
so could i use a zvs flyback driver
