  • Guests: 33
CT2 (37)
Josh Johnson (46)
01/21 Banana Man (41)
01/21 TheAnomaly (13)
01/23 GimpyJoe (36)
New VTTC
Reaching
Sat Mar 18 2006, 10:48PM Print
Hi
Its time to start my newest project
my new tube arrived a few days ago and i love it. its an eimac 4-250a tube i bought from ebay very cheap. now i have everything together to build a nice vttc. i have some 590pf 30kv doorknob caps lying around, some power resistors and a mot.
now i have a question on the oldies in vttc coils.
what size and wire gauge should i use for my secondary coil to get the best performance? Toroid or no toroid?
heres a pic of my beauty
1142722108 76 FT0 Bigtube
Sun Mar 19 2006, 12:03PM
secondary: 0.25 mm magnet wire
primary: 2.5-4 mm^2 insulated wire
grid coil: 0.5 mm magnet wire
A bit of topload (a little toroid) helps.
Of course, you would use what you have around....
Reaching
Mon Mar 20 2006, 06:55AM
mhh, okay, ill use something around 20 primary turns, 20 feedback turns. 11x23cm secondary with 0,2mm wire, little topload. tank cap around 2,2nF
i finally tested the tubes filament, seems to work fine on my selfwound 5volt 20A transformer cheesey
Matt Edwards
Sat Jul 17 2010, 04:38PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Good info here
and here
