  • Guests: 38
GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
Big Red. The Coil (now with 1st light pics)
first  3 4 5 6
Cain
Fri Aug 01 2008, 06:05AM
Cain Registered Member #624 Joined: Tue Apr 03 2007, 07:50AM
i would go brass dome nuts on your gap.. i think you will find hardened steel will burn away even faster than mild steel as is contains more carbon.. i use brass door knob and brass domes on mine and it works great!!
teslacoolguy
Sat Aug 02 2008, 03:51AM
i put brass dome nuts on it today. First light is tomorrow at the teslathon.
Dr. SSTC
Sat Aug 02 2008, 05:31AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
teslacoolguy wrote ...
you say first light tommorow does this mean that your turning it on tomorow for the first time
if so doesnt it take a while to tune it coz it takes me a while
or is there a secret that i dont know smile
teslacoolguy
Sun Aug 03 2008, 04:32AM
I did 1st light today and ended up with 5' streamers.
teslacoolguy
Wed Aug 06 2008, 01:14AM
Wee!!
1217984867 1107 FT47960 Image1
1217984867 1107 FT47960 Image2
1217984867 1107 FT47960 Image9
I also noticed that the stationary gaps on my rsg got so hot that it melted the plastic standoffs so i came up with a nice precision machined heatsink solution wink
1217985229 1107 FT47960 Both Gaps
1217985229 1107 FT47960 Gap Closeup
Dr. SSTC
Wed Aug 06 2008, 09:42AM
John are you thinking of making a DRSST now
Wed Aug 06 2008, 10:08AM
Cool, gj teslacoolguy.
Kristian
Wed Aug 06 2008, 10:50AM
Kristian Registered Member #611 Joined: Wed Mar 28 2007, 11:40PM
Nice heat sinks! Let me know how they work for you. With the power level you are running, you might want more "fins" and a fan on them, maybe.
Alexandre
Wed Aug 06 2008, 05:02PM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
cool
teslacoolguy
Sun Aug 17 2008, 04:04AM
Tonight i did a demo for a bunch of people. I was pretty good. It still needs some more tuning to get longer sparks but it sure was impressive. here is the youtube vid. Link2 Here are some pics of my setup.
1218945594 1107 FT47960 Setup
1218945594 1107 FT47960 Rsg Close
I still need to put the rsg under the coil so i dont have as much leakage inductance and i can tap the primary out 1 more turn.
1218945780 1107 FT47960 Me  Coil
Finally the coil next to it's creator wink
first  3 4 5 6
