  • Guests: 37
GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
Big Red. The Coil (now with 1st light pics)
Dr. SSTC
Fri Jul 04 2008, 07:37AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
what is the resonant frequency btw
Mike
Fri Jul 04 2008, 07:39AM
Mike Registered Member #58 Joined: Thu Feb 09 2006, 05:40AM
Coil is looking good man! Keep it up. cant wait for first light, hopefully mine will be up soon too.
Offtopic: jovica93 next time use the edit function instead of posting another reply. It will keep the mods happy.
teslacoolguy
Mon Jul 07 2008, 03:02AM
Thanks..... The res freq is 109 khz. Anyway i fot the tufnol for the rsg disk today so tomorrow i will work post pics of hopefully a completeed rsg disk.
teslacoolguy
Tue Jul 08 2008, 05:01AM
Today i was able to make the rsg disk. It is made from 1/2" tufnol and has 8 electrodes spaced roughly 2" apart.
1215492926 1107 FT47960 Disk Done
1215492926 1107 FT47960 Disk Micrometer
1215492926 1107 FT47960 Disk Back
1215492926 1107 FT47960 Disk Center
Coronafix
Tue Jul 08 2008, 05:26AM
Nice work!! I assume you are going to use tungsten rods set in those holes?
How are you fixing the electrodes in?
teslacoolguy
Tue Jul 08 2008, 06:08AM
Actually the electrodes are going to be industrial grade hardened steel threaded studs because tungsten would be to hard to fasten to the disk.
Tue Jul 08 2008, 07:17AM
Might i suggest using collars to lock the rods in place? Or possibly tapping a set-screw in from the edge of the disk, but ive never worked with tufnol so i dont know how tapping it would turn out.
Experimentonomen
Tue Jul 08 2008, 09:22AM
What the hell is tufnol anyways ???
Tue Jul 08 2008, 09:29AM
What the hell is Google anyway? Link2
teslacoolguy
Tue Jul 08 2008, 11:48AM
Steve Ward wrote ...
Im not sure how well you can tap tufnol but i am using locknuts and i might tack one side with a welder depending on how well the nuts hold.
