  • Guests: 64
What frequency does a camera circuit operate at?
Plasmaarc452
Wed Jun 18 2008, 11:06PM Print
Plasmaarc452 Registered Member #1394 Joined: Sun Mar 16 2008, 06:18PM
I am trying to make my own camera circuit by reusing the transformer, I will then use a transistor and a 555 timer. My main question is at what frequency should I make the 555 timer oscillate?
________________________________________________ __________________________________________________ __________________________________________________ _____________________________
Also, I built a simple 555 driver using a capacitor and 2 resisters in an astable configuration. Now for some odd reason when ever I increase the voltage it starts to oscillate the led faster. Is this a normal function of the 555 or is my circuit messed up? I think it has something to do with the capacitor taking longer to discharge at the higher voltage but I am not sure.
Thanks!
Avi
Thu Jun 19 2008, 12:37AM
it is a feedback circuit, frequency changes as the capacitor charges.
Since you can hear it, id suggest testing between 10Khz and 20Khz
rp181
Thu Jun 19 2008, 01:21AM
Just play with it, find the best preformance.
Shaun
Thu Jun 19 2008, 04:04AM
With no load mine is 14kHz (1 AA only). Although, if you want to run a bit more voltage you could probably use around 20-30kHz.
