  • Guests: 46
VTTC beginner questions
Wed Jun 18 2008, 09:23PM Print
Hi all
As im reading up on vttcs I have come across some questions, still havent got a tube to work out from as its hard to find cheap matched or single larger tubes in Denmark.
1. When reading maximum values in datasheets for tubes, is it grid-modulated rf amplification class c i should look at?
2. A radioamateur told me a tetrode can be run as a triode by grounding the screen, but will this work in a vttc? since there really aint a ground of same maxpotential of the grid driver. Is the same trick pulled with pentrodes?
3. Winding the chokes wire around the resistor, does it serve any purpose but keeping it tight?
4. When simulating a coil in javatc, should i try to reach the surgested coupling? it often places the primary(helical) halfway under the secondary to reach the surgested.
5. steve mentions in his faq that smaller coils give smaller sparks than large coils at the same powerlevels, and with the general rules of thumb from the hvwiki im split between going 100mm or 160mm diameter secondary, both should be good at power around 500-1000W, experienced surgestions are welcome
I properly have some more questions that are forgotten now, so this will have to do.
