  • Guests: 65
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Poorest Man's SSTC
Hazmatt_(The Underdog)
Mon Jun 16 2008, 10:27PM Print
HEHE, well, not exactly. See the Idea is I'm studying coupling and well, I was trying a triac module using 16 VAC and input via my signal generator but the 15V square wave from the generator just wasn't saturating the triac module enough, so I thought what the hell, I'll just use the Iggy coil driver idea and see if it will work, AND IT DOES! Now mind you I am studying the coupling for a SGTC so I don't need or want big sparks, I just want to see the beating and frequency splitting in the system. The setup gives me about 2kv I would say because the sparks are about 3-4mm overall, so its perfect to be divided down and characterized by instruments. The car jack is to raise and lower the coil so I can see where the optimal response is e.g. see the notches without making something too rigid or permanant. It gives me 17 inches of travel, and on top of that I can insert or remove pipe couplers to gain a very wide margin of coupling. ^^ I think its pretty smart.
Specs:
1000W lamp dimmer
decoupling cap: 30uF 6x 5uF @ 100VAC, and...heh... I'm putting 120V through them... no wonder they buzz. I'll have to put a couple in series. I wasn't looking when I threw it together, so that explains it.
Tank cap: .02uF 4x .005uF, I wasn't sure how well the small 630VAC caps would hold up in the tank but it looks like they're happy.
Primary: I think 42uH, I have to check later, but that's not really all that important
Secondary: 44mH 4.6" secondary 28 AWG ~ 1000T
Output: 3-4mm spark lenght, even shorter then my flyback driver! heheh.
So there you have it, the poorest man's SSTC, that is if you don't have hours and hours to design a PCB, wait for parts or what have you.
014f
009f
010f
012f
Avi
Tue Jun 17 2008, 05:06AM
I managed to make one with a single mosfet flyback driver(mosfet+555+ucc drivers, changed the cap to get a higher frequency range on the 555). It managed reasonable length sparks when a capacitor charged to 240v was connected to it.
Aslo worked changing the 555 circuit for a antenna+invertor chip.
The mosfet had zeners and a mov across it
Reaching
Wed Jun 18 2008, 05:50PM
hrhr, i managed to build a sstc with only 3 parts. a mosfet and two resistors. its a simple feedback oscillator and the mosfet needs no heatsink.
a bit difficult to get the feedback coil right, but its the simplest coil i ever build
Wed Jun 18 2008, 06:23PM
I've also made a triac sstc before, 5mm sparks or so. The main problem is the speed of the triac, if one could get fast high-current triac module, it would make for a nice OLTC I think.
On the note of super simple things, I once managed to get a HV transformer from photocopier going with just one mosfet, nothing else. Made 1cm sparks from 4 AA batteries.
Wed Jun 18 2008, 08:46PM
Reaching wrote ...
Btw where is that schematic located? I saw it before. I would like to give it another go. Maybe experiment with different component values.
Avi
Thu Jun 19 2008, 12:43AM
Reaching wrote ...
what?
is this the 'joule theif' circuit or something?
Reaching
Fri Jun 20 2008, 11:20AM
Heres the shematic
1213960818 76 FT47585 1mosfetsstc
Sat Jun 21 2008, 07:36PM
hehe, part of this is a joke you guys are missing. The joke is that the arc length is miniscule and its a poor SSTC as far as performance goes, but I didn't want huge arcs because I just need enough output to go to a divider and into the scope. See I'm looking for coupling characteristics, so that joke sorta got missed.
Other then that I do have a mosfet driver but remember the primary is copper tubing. Without a decoupling capacitor you're just going to have a hot transistor.
The other problem is I need low frequency switching so I can mimic the spark gap, otherwise I would have a CW amplifier driving the input insted of a triac.
I have yet to really look at the output, and now I have a couple of days off, so I hope this gives me what I'm looking for.
