  • Guests: 45
Turn-off delay times and pulsed current ratings of IGBT's
Thu Jun 12 2008, 10:17PM Print
Timo Registered Member #1538 Joined: Thu Jun 12 2008, 07:28PM
Hi
At the moment I am building a DRSSTC for the „Physikshow“ at the University of Bonn, where I study physics. Since it’s not my first solid-state coil and I spend a lot of time reading, I lately got things running. I tried to stay close to Steve Ward’s “General Guide to DRSSTC Design”, especially for the driver, OCD and feedback loop. I use a H-bridge topology, primary is 10-15 µH, 66nF, secondary is 45cm (17,7in), 11cm (4,3in) diameter, 0,3mm (28AWG) wire. Resonant frequency with topload (14pF) is ~200 kHz.
No big surprise so far, I hope. But I’m somewhat unhappy with the IGBT’s performance. I tried STGW39NC60VD (I_max = 80A, I_puls = 220A, Gate charge at 15V = 126nC, to247) and HGTG20N60A4D (I_max = 70A, I_puls = 280A, Gate charge at 15V = 142nC, to247). The STGW39NC60VD was able to survive the higher pulsed currents.
Now I would like too know what you experienced about I_puls ratings: are they useful, or do you prefer “bigger” IGBT’s like the 40n60 or 50n60, although they might, in some cases, have lower pulsed ratings?
My second question is about delay times: dose anybody know if a delay of about 300ns between the zero-crossing of the prim. current and the switching transition of the H-bridge’s output is about what is suspected for this circuit? It seems to me that the IGBT’s are already again carrying about ¼ * Imax than for ~150kHz operation. Is a turn-off delay time of about 200ns (STGW39NC60VD) to much?
Thanks in advance
GeordieBoy
Fri Jun 13 2008, 10:38AM
The IGBTs will always switch sometime after the load current (primary current) has passed through zero. This is the case because it takes a finite time for the "zero crossing message" to propagate from the CT, through the control logic, gate drive amplifiers and GDTs to make the IGBTs eventually switch.
By the time the IGBTs switch in a DRSSTC, the current has already changed direction. It has left the active channel and started flowing in the co-pack diode long ago. This soft turn-off is the situation you want since it minimises turn-off current tailing in slow IGBTs. However, you don't want to wait too long after the zero crossing to switch both IGBTs because the one that turns on has to pick up a larger current from the opposing co-pack diode exacerbating reverse-recovery problems in that device.
Phase-lead networks (allpass filters) and PLL's are two ways to compensate for the effects of these propagation delays through the control and drive electronics. Using these techniques you can ensure that one device is turned off as soon as possible after the current reverses direction, and that the opposing device is turned on as soon as possible after the first device is out of conduction.
-Richie,
Fri Jun 13 2008, 02:14PM
Oh, yes, of course you are right. None of the IGBT’s has to switch off the current. It somehow twisted my mind!
But still one of them has to turn on while about ¼ Imax is flowing through the co-pack diode of the other device. This will hopefully be about 100A, which the IGBT has to pick up, as you mentioned.
I am not that familiar with IGBT’s yet. 100A just seems high to me, because some of them have a SOA of “only” 100 – 150 A at 300V. But, however, if you say 300ns is not WAY to much, I will try once again.
Can you also help me with the pulsed current ratings? I’m still unsure which is the right way: using an IGBT with a higher puls rating, or one with a higher current handling ability in general? To say some numbers, would you prefer something like the HGTG20N60A4D (I_max = 70A, I_puls = 280A) or the STGY50NC60WD (I_max = 110A, I_puls = 250A)?
Thanks again, you already helped me a lot!
Tom540
Fri Jun 13 2008, 03:02PM
Tom540 Banned on 3/17/2009.
Timo wrote ...
"To say some numbers, would you prefer something like the HGTG20N60A4D (I_max = 70A, I_puls = 280A) or the STGY50NC60WD (I_max = 110A, I_puls = 250A)?"
I would say go with the pulsed rating. I am using the hgtg20n60a4d IGBT's and they are great. They can handle quite alot of power. Also maybe go with the one with faster switching times.
Fri Jun 13 2008, 11:36PM
Hi Tom540
Thanks for this information. May I ask you if you use a circuit that delays the switching event noticeable, similar to Steve Ward’s? And if you do, would you tell me how much and what the maximum current is you allow for reliable operation?
I’m somewhat interested in how much the current may rise before the IGBT takes over.
Tom540
Sat Jun 14 2008, 12:24AM
As far as delaying the interrupter I have used a similar circuit but i don't always use one. If I were to use primary feedback then I would say it is probably needed. The only delay for me is the paralleled resistor and Schottky's on the gates of the igbt's. I think my igbts are only running at half the rated pulsed current. Its been awhile since i've measure it though. Maybe Ill take a measurement today.
Marko
Sat Jun 14 2008, 12:25AM
Hi guys;
One related thing. IGBT's in DRSSTC switch leading current which causes their integrated diodes to forcibly recover. This looks like a very short shoot-through condition and causes a short, spiky voltage transient at turn-on (the point where the IGBT ''takes over'' the current from the diode as you say, and slamming full supply voltage across it).
For some reason, lots of people were and still are *extremely worried* about these voltage transients, which ended probably as most blamed thing for IGBT failures (while in almost all cases some other reason is found later). People have gone through great lengths trying to remove those ''voltage spikes'' (ultra low inductance supply buses, huge amounts of decoupling caps, stacks of TVS's, slowing down the gate drive...)
To me, a simple logical way for removing the ''voltage spikes'' would be to introduce small commutating inductance across the bridge output, but before the CT, to provide few to few tens of amps of reactive current and make the system switch lagging current in overall.
This would introduce ZVS at cost of having somewhat hard switched turn-off, and we would not see those annoying spikes anymore.
The question is, of course, how would this make sense at all, since in a low duty cycle system like DRSSTC losses due to recovery and lack of ZVS are completely negligible, and commutating inductance may just do more damage than good by introducing additional current to be switched.
So, should we just explain everyone that the ''voltage spikes'' are *good*, and to stop worrying about them? Many still seem to think the IGBT will pop like a balloon if anything just touches over it's rated voltage, even if for just few ns.
Marko
GeordieBoy
Sat Jun 14 2008, 12:50AM
Adding commutating inductance to pulsed high-power IGBT bridges in DRSSTC apps is in my opinion counter productive. Firstly average turn-on losses due to diode reverse-recovery are still relatively low even though peak dissipation may be high in a particular DRSSTC. Secondly, the addition of a commutating inductor to introduce enough lagging magnetising current to make the total inverter current lag would mean a significant circulating current would need to be supported by this inductor without saturating or incurring significant I²R losses. Thirdly, a net lagging inverter load current would mean IGBTs now have to interrupt significant load currents causing significant current tailing and turn-off losses in all but the fastest of devices. (You will also likely still see voltage spikes and ringing, this time due to the catch-diodes limited ability to pick up the tens or hundreds of amps being rapidly turned off by the IGBTs)
Finally another problem with a commutating inductor connected directly across the output of a PULSED bridge is in maintaining instantaneous volt-second balance to always keep the triangular current waveform symmetrical about the 0 amps line. The first half cycle actually needs to be artificially shortened to a quarter cycle in length. Otherwise the current will integrate up too far in the first half cycle and there will be a net DC bias to the magnetising current.
The best ways to deal with the turn-on current spikes resulting from forced diode reverse-recovery are as follows:-
1. Turn off the previously conducting IGBT device as quickly as possible after the load current goes through zero and commutates to the device's copack diode.
2. Turn on the opposing device to catch the free-wheeling current as soon as possible after the end of the first device's turn-off delay time. This prevents cross conduction.
3. Turn on the new device with a controlled gate voltage profile so that the stored charge in the free-wheel diode is swept out in a controlled manner with a limited peak current. The device is essentially progressively enhanced to support only the rising load current as it grows in amplitude without desaturating the IGBT.
4. Minimise stray inductance in the IGBT, diode, bus cap clamping loop.
Limiting peak reverse current through controlled turn-on and minimising DC bus stray inductance both limit the voltage spikes that result from excessive Ldi/dt.
Hope this helps,
-Richie,
Marko
Sat Jun 14 2008, 01:15AM
You are right. That is exactly the same problem that happens with iron transformers when plugged into mains at voltage zero cross, which causes a quarter cycle of extra Vs, saturation and drawing of excessive currents.
The condition takes many cycles to resolve as real part of impedance removes the energy, so in DRSSTC I would practically have DC flowing through commutating inductor.
Well, I guess that could be done with PLL as you said. My point was, aren't we actually worsening the condition by trying to somehow introduce lagging current just to remove the very ugly looking 'voltage spikes', which actually aren't any harm at all.
We would get soft recovery and ZVS which are negligible benefit for a pulsed system.
IGBT's are usually advised to drive leading current to maximize zero current turnoff, even in CW, as their diodes are fast and output capacitances small compared to same rating mosfets.
