  • Guests: 29
01/13 si2030 (62)
Ignition coil on mains
Mates
Wed Jun 11 2008, 11:28PM Print
Hi guys,
Here is my latest update of an ignition coil powered straight from the mains (220V AC). BUP314 transistor is switched directly by TL494 at 6 KHz. The output voltage of the coil is around 60KV so it must be dipped inside an oil bath.
Video is here: Link2
1213226826 1025 FT0 Iggy Driver
1 Copy
Thu Jun 12 2008, 12:20PM
I would use fullwave rectified mains (probably with a capacitor in series for current limiting), you can then draw out the arcs much longer than the starting distance because of continuous-wave operation.
And be careful, the coil will overheat if you run it too much current.
Nice vid smile
Berni
Thu Jun 12 2008, 03:19PM
Berni Registered Member #1132 Joined: Mon Nov 19 2007, 06:15PM
Yep try rectefied mains, gives a nice high current 300V.I used a 1:1 isolation transformer to limit the current at switch on since i had two 2200uF 400V filter caps.But i guess it would be better to use much smaller ones (like the filter caps in PC powersuplys)
And yeah as he sead ignition coils can heat up quite some when driven at these powers. With my driver i pushed a coil so hard it arced over internaly to the metal can and then to one of the poles.I was driving it at resonance with a H bridge directly off rectefied mains.
Thu Jun 12 2008, 05:42PM
Can you hear the 6khz when you operate this thing? It doesnt seem to be in the video (only 50hz), and i was wondering if that was simply the low quality audio?
Maybe its worth removing the ignition coil from its metal can, so you can have a larger tank of oil for the whole thing, it also removes the possibility of the can rupturing from internal pressure.
Mates
Thu Jun 12 2008, 06:52PM
Steve Ward wrote ...
It is the sound quality; otherwise it squeezes like crazy...
I've never have a problem with overheating the coil by operating it with this driver despite it sucks 3.5A from the wall (220V). That's the advantage of pumping high voltage pulses into the primary...
Berni
Fri Jun 13 2008, 05:06AM
Well no wonder 50Hz is so dominant because he is basicaly choping up the 50Hz mains signal at 6Khz. If you send in DC at the points you put in mains you should get much more power. Just grab the first moderetly sized rectifier bridge you find and stick on some caps in the 500uF range.If you have trubles of pluging this thing in and your breaker trips then just use something as a balast. I found a mains traformers secundary can be used as a balast with the primary shorted.
Also the 70uF filter cap dosent realy need t o be that big. I used only 2uF and works great.At these high freqencys caps dont realy need to be big anymore.
Oh and i dont have any plans on riping up the ignition coil. But i do have plans of trying to make a homemade single layer HV transformer.And try induction heating too
Mates
Fri Jun 13 2008, 01:16PM
Berni wrote ...
Hi Berni, I'm affraid you do not understand the circuit. I cannot use the DC - it wouldn't work. Actaully it would make only single spark and that's all. The design with 2uF cap you are talking about is most likely half bridge, but this is single switch and it is the changing phase (AC) which allows to discharche the big cap. The cap must be so big because the discharging is only at 50Hz while the charging is at 6Khz (through the primary of the coil). I can rise or lower the power by adding more capacitance of the big cap and I know for sure that at 2uF the power is very low...
The usage of a single switch design directly for rectified (and cap smoothed!) mains would be a certain killer for the transistor. Maybe it could be solved with some kind of curret limitter but that's completely different circuit design and I would rather go for half bridge anyway...
Cheers Mates
Fri Jun 13 2008, 01:51PM
If you want to have fullwave rectified mains and still go with the weird current limiting, I suggest you this circuit:
1213365085 152 FT47136 Psu
Berni
Fri Jun 13 2008, 02:10PM
Yeah i used a full H bridge to drive it. I used a garden hose,glass and laqour to keep it from arcing over. But that wont help if the coil arcs over internaly and bye bye coil.
So i guess its the best to use just a half H bridge.
That transistor of yours is quite beefy so it should handle big powers in a bridge.
Good luck!
Hon1nbo
Sat Jun 14 2008, 01:04AM
take a look at this: http://powerlabs.org/gmheicslr.htm
