  • Guests: 36
Proud Mary (62)
omegalabs (39)
Plasma Lover (32)
09/16 Michael Witt (36)
09/16 AleSeg (15)
09/17 Jyardana (41)
coil gun
1 2 3 4
rp181
Wed Jun 11 2008, 12:31AM Print
I've been working on a coil gun. I am working on them for a science fair project in determining the best way to affect effeciency. I hope to get 5kJ worth of Capacitors, but im still working on getting them. Ile update as i get items/construct.
Parts i have:
3x ST180S12POV (SCR's) - Datasheet: Link2
4x Fast recovery diodes: R6021225HSYA - Link2
5x 300 watt, 1000ohm bleeder resistors
1' x .5" Hymu-80 rod - will become proectiles
Parts i need:
Capacitors - 6x 400v 2900uf -- Shipping --
Plans/Pics:
The SCR's and Diodes, with AA for comparison:
T DSCF0112m 5a749e0
Bleeder resistors
fairly big, larger than expected
T DSCF0083m 5f58642
Heres some renderings done on Rhino of the railgun and coilgun. Capacitor bank is shown on railgun, and railgun is ghost rendered. Each little sqare is 1/4in, and each big square (marked by darker lines) is 1in.
Coilgun:
T 61020081432m 48ee39c
Specs:
14 in long, 3 coils. AWG wire - 12
624J each stage
I have decided on using a quad comparator and phototransistors to trigger.
Update
After a long delay, started project again. I ditched the railgun, and im using 624J X 3 for a multistage coilgun. Heres the coil gun:
T 1001499m Fc03d93
Capacitors are shipping. My charging will be a voltage multiplier for 110 to ~600v. Capacitors will be in sets of 2 for each stage.
Update 2
Ive mounted everything on a base and wired the anti-parrallel diodes and SCR's together. Now i am just lacking the capacitors and triggering system. I have started making a triggering system using a LM339 Quad-Comparator. If you look at earlier pic, you can see the that the IR Emitter/Reciever are built in. Ive got the basic LM339 working, but i gotta make it work with a 2SB772 NPN transistor for it to switch the SCR's.
Heres a pic:
T 1001500m 94914f0
The empty space will be where the Capacitors will go. The (+) of the cap bank will connect to the studs of the SCR's and the (-)'s will connect to the Diode (screwed down part). In the upper right is my LM339 triggering system prototype. The Aluminum thing right after the CG is a simple set of IR Emitter/Recievers i will use with my PC to chrono the projectile. Ferroxcube, chtechnology, and Powerohm logos are on there to show who donated parts.
ea6b607
Wed Jun 11 2008, 01:15AM
ea6b607 Registered Member #1320 Joined: Sat Feb 16 2008, 01:31AM
how's your machining facilities/ tools/
rp181
Wed Jun 11 2008, 01:55AM
a 1/3rd horsepower Drill O.o
Doing it at school,so table saw, radial arm saw, drill press, band saw, metal bandsaw, horizontal bandsaw, drum sander, belt/disc sander, scroll saw, spot welder, mig welder, arc welder, and a foundry O.o.
Lakeowner
Wed Jun 11 2008, 08:53AM
Lakeowner Registered Member #1370 Joined: Mon Mar 03 2008, 09:01AM
Why are you using resistors in series with your coil? I think they decrease performance considerably.
rp181
Wed Jun 11 2008, 02:08PM
The inductor and resistor represents the coil, as it will have resistance and inductance.
Bjørn
Wed Jun 11 2008, 02:12PM
The resistor is usually implied. When you draw it like that people will think you have added an external resistor.
rp181
Wed Jun 11 2008, 03:41PM
Updated schematic, would that triggering work?
Andyman
Wed Jun 11 2008, 05:51PM
If I recall, it's best if you have a resistor of about 1k on the gate of the fire scr, if you're running straight from a 9v battery.
P.S. What program did you use for the schematic?
edit:(on a random side note, 100th post!)
rp181
Wed Jun 11 2008, 06:10PM
The program is microcap (evaluation).
I will be using a laptop power supply (14.5v) with a resistor to trigger. I tested it and it works. The gate max is 20v, so it should be fine.
Also works without resistor, but just to leave a wide saftey margin.
Electroholic
Wed Jun 11 2008, 06:52PM
use max gate current to calculate resistance, u want a good kick to the gate.
