  • Guests: 47
what role does the MMC capasitor play
teravolt
Sat Mar 18 2006, 05:10AM Print
In a series resonant circuit voltage is high and current is low, in a parallel resonant tank circuit current is high. When I started usind my H-bridge I was using the MMC in a parallel configuration thinking more circulating current in the primary would generate more voltage. Not the case. As soon as I went to a series MMC-primary circuit voltage on the primary and secondary went up. I guess that proves the start of this paragraph. In a sstc should the MMC be resonant with the primary and secondary or is the MMC an over glorified cupling capasitor. I am with idia that in series resonant primary and a resonant secondary that are tuned at the exact same frquency have the gratest output. Probly this well known what do you think?
EEYORE
Sat Mar 18 2006, 07:00AM
The MMC+primary are tuned to the fres of the secondary.
Matt
Sat Mar 18 2006, 01:29PM
For the conventional SSTC, the series primary capacitor is just a coupling, or DC blocking capacitor and has little effect on the performance of the coil. However, for DRSSTCs or double resonant solid state tesla coils, the primary capacitor does play a very important part in the circuit.
