  • Guests: 86
Upgrade of my high power single switch SSTC
Mates
Sun Jun 08 2008, 08:21AM Print
I simplified the design (it is powered straight by non-rectified 220V AC mains) and increased the power of my single switch…
1212912784 1025 FT0 Scheme
How it works:
It employs three BUP314 Link2 transistors in parallel switched by TL494 followed by UCC37322/1 gate drive and GDT. The resonant frequency of the coil is 380KHz. The coil works in Class E and to achieve Class E at 2.5KW which the coil sucks from the wall needs a special trick. The PW of the switch pulses is very short (only 1us) and the switching frequency is only half the resonant frequency (180KHz). Big advantage of this concept is that through the opened transistor the C1 is discharged into the primary and this discharge has a very short peak (most of the energy goes within first 300ns). Thus, the turn off time of the transistors is not longer an issue and relatively slow IGBT type of transistor can be easily used. Such ultra short pulses are relatively easy to place to the zero voltage transitions of the L1/C2 resonator by simple tuning of the coil (at low input voltage). The huge C3 capacitor works as a non-inductive current limiter with very low resistance. It basically determines the AMP peak of the C1 discharge. The C3 is made of many PP capacitors (used in asynchronous motors) and by connecting and disconnecting some of the caps the power of the coil can be regulated.
Here is the video of the coil in action… Link2
Comments welcomed
1212913121 1025 FT0 Pulses
Red - secondary waves
Black - driving pulses
BTW: Would be great if somebody could help me to solve a feedback for this coil - I'm sure it would increase the spark lenght...
Sun Jun 08 2008, 10:31AM
Looks like you reinvented the OLTC with an extra capacitor. suprised
Mates
Sun Jun 08 2008, 12:21PM
Dr. Conner wrote ...
I don’t understand where you see similarities with an OLTC concept. I checked all the OLTC schemes on the internet and the only similarity I see, is that they are also connected to the wall plug-in.
The OLTC concept as I understand it is a substitution of a spark gap a by a semiconductor. It means that the switch device is in parallel to the L/C. Next, the power source for a common OLTC is rectified mains with some kind of current limiter (a choke or transformer). The driving pulses for the OLTC transistor are completely unrelated to the resonant frequency of the coil, usually kept in low bps rate. None of these features are part of my coil – so why is it OLTC for you? suprised
My coil has a transistor in series with primary and is in parallel with the resonant cap (class E concept). As a power source I use non-rectified mains and the driving pulses are exactly 1/2 of the resonant frequency of the coil (In case I’m out of tune, no or very little sparks appear).
9 Copy
5 Copy
Mon Jun 09 2008, 04:45AM
Wow, Great coil! I think i will buy some igbts and other junk and make this. Thanks!
GeordieBoy
Mon Jun 09 2008, 12:36PM
Just to avoid confusion, this circuit is not operating like a Class-E RF amplifier. If anything it is operating closer to a Class-C frequency doubler.
Class-E operation is characterised by a damped sinusoidal voltage waveform, where the switch turns on at zero-voltage and with zero-current.
Some info including waveshapes here:
-Richie,
Mon Jun 09 2008, 02:21PM
Looking good Mates, and interesting driving scheme.
Mates
Mon Jun 09 2008, 02:42PM
GeordieBoy wrote ...
-Richie,
Thanks for the link and the Class comment...
I do not understand the Class C - how it works, whether it has also a resonant cap or not. Still, I believe the signal is actually damped - you can even see it on the osciloscope picture. The only thing which is different from classical classE operation is that I switch every second wave. I also tried to switch every negative wave (this means the full resonant frequency of the coil). It worked very well, but only two seconds - than I destroyed one of the transistors so I went back to the safe waters of the resonant freq/2 (BTW: paralleling of the transistors have the big advantage that you destroy only one, in case you make some mistake. The bridge design is never so generous...).
Any idea about the feedback for this coil?
GeordieBoy
Mon Jun 09 2008, 04:34PM
Feedback will be a challenge if you have to drive it at f/2 !
