  • Guests: 83
Inducktion (32)
Standa (31)
nabzim (33)
12/23 David (39)
12/25 Kolas (18)
Railgun begginings and questions
rp181
Wed Jun 18 2008, 01:34PM
Not everyone is creative enough to improvise =)
phil
Sun Jun 22 2008, 03:28PM
phil Registered Member #314 Joined: Mon Mar 13 2006, 03:12AM
Running into a bit of a problem. Well i still havent been able to salvage any IGBT's or SCR's so i'm still working on that. But i also wound the first coil for the boost converter and to be honest i'm not too thrilled with it. does anyone have any techniques that you think work well? i'm winding 22AWG magnet wire around a ferrite core. Thanks in advance =)
rp181
Sun Jun 22 2008, 05:17PM
Call a local GE facility (not appliances, like industrial stuff) and ask for the "elfun" people. Ask them if they have any SCR's or IGBT's, there the ones who take apart old equipment.
phil
Wed Jun 25 2008, 01:19AM
I was just given two "Duratrax BLAST!" motor controllers, each have 12 MOSFET's so i think i'm going to go with those instead of the SCR's.
phil
Sat Jul 05 2008, 04:16PM
Alright so i hooked everything up and turned it on, The voltage coming out of the boost converter won't go high then .6V..... i can adjust it between .5 and .6 volts and obviously something is horribly wrong. I've narrowed the problem down to the coil i made, or the MOSFET i'm using. Any suggestions?
Backyard Skunkworks
Sun Jul 06 2008, 03:09AM
The two things that come to mind are: 1. are the MOSFETs hooked up right? 2. Does the coil have the right inductance?
It's always something obvious!
Sun Jul 06 2008, 03:42AM
Its likely that you havent done any calculations for this boost converter, and that you are simply saturating the ferrite core. If you wish to proceed without working out any math, i suggest 1) try upping the operating frequency, and 2) lower the duty cycle of the MOSFET, and 3) adding more air-gap to the core, and 4) adding more windings to the inductor.
All of these things will reduce the possible optimal performance of the converter, but if you saturate your core, then you will get squat for output.
Oh, and you should be using a high-speed diode at the output of the converter (not sure if that was covered).
phil
Sun Jul 06 2008, 06:52PM
Checked the MOSFET and i had it wired backwards ><. It's wired correctly now, however the converter is hovering between 4.85 volts and 5.21 volts, and MOSFET is getting HOT. Is it possible that i'm running the MOSFET at too high a frequency? i'll look into the coil next.... might just buy one instead of making it.
Chris Russell
Fri Oct 03 2008, 02:25AM
Chris Russell ... not Russel!
I cleaned up this thread a bit. This thread is about phil's coilgun. Do not pile unrelated questions on top of this thread. Start a new topic if there's something new you'd like to discuss.
