  • Guests: 41
Troubleshooting DRSSTC
Ken M.
Sun Jun 08 2008, 12:25AM Print
Hey Folks,
Just got all the stuff to build my DRSSTC, got it all set up and tried to test fire it With 24VDC on the 1/2bridge nothing happened but the usual of the GDT making noise since there isn't a 100KHz or so Frequency being applied.
My question is, Does the DRSSTC follow the same start up principle as a SSTC where as when the drive electronics are powered up it causes a momentary spike to go threw the GDT and "fire" one of the IGBTs, causing current to flow threw the primary and inducing a signal in the feedback system starting the self oscillations, or does it go by a different set of "mechanics"?
Bennem
Sun Jun 08 2008, 09:08AM
Bennem Registered Member #154 Joined: Sun Feb 12 2006, 04:28PM
Hi Ken,
Yes...your interrupter signal initiates the oscillations.
Have you tried reversing the phase of your feedback transformer?
is your primary tuning way off?
My DRSSTC's seem to start up ok at around 30volts on the bridge.
All the best,
Mel
Ken M.
Sun Jun 08 2008, 02:49PM
Yes, I thought of reversing the phase after I made the post, tried it and heres the wave forms I get at certain points.
5 Brdige W Test 1212936310 618 FT46866 A
1212936404 618 FT46866 B 1212936404 618 FT46866 C
1212936404 618 FT46866 D
I don't think my tuning is off, calculated up the figures but I might have.
Ken M.
Mon Jun 09 2008, 11:57PM
I realize its not been 48hours, But i think this constitutes an update.
Yea bennem, Switching the Feedback Xformer cleared up that part of the circuit, Cuz now I get Gate waveforms that look decent
1213054435 618 FT46866 Sd530623
Although when I try to get a more detailed look at the gate waveform I get this
1213054540 618 FT46866 Sd530620
Then when I scope across the MMC and the primary I get
1213054630 618 FT46866 Sd530624
Then if I scope across the Feedback Xformer and the sprimary I get this
1213054806 618 FT46866 Sd530626
Then My last shot of the proof that its partialy resonating, the 2nd ch (yellow) is reading 265V(pk-pk)
1213054911 618 FT46866 Sd530627
*~NOTE~*: power applied to 1/2 Bridge is 24VDC from a DC power supply capable of 7A (loaded).
Now I also have some questions, if the OCD trips Just momentary at random intervols, is It working or is it just accidnetaly tripping? A long that same line, when the power was disconnected from the 1/2 bridge and the cap discharges then the GDT Squeals (typical of not getting the correct freq) But also the OCD LED lights completely if I adjust the OCD pot it either gets brighter or at some point it shuts off, Does this mean its Not operating correctly?
Since DRSSTCs are very similar i decided to switch the ends of the primary which didn't turn out too well since it caused the IGBTs to get very hot to the touch, So would this mean that my original phasing is correct or would the phasing that caused the overheating to be correct?
Tue Jun 10 2008, 02:59AM
Something still looks nasty here, those "sine" waves arent very sinusoidal. Im not sure what the issue is, but i dont think its working properly yet.
Primary/secondary phasing of the *Tesla* coil doesnt matter one bit. If one setup made the IGBTs hotter, then that is completely lost on me, it shouldnt matter one bit. What does matter is the phasing of the feedback CT, and thats all.
The OCD should be very solid, not randomly firing, unless of course your primary current is randomly exceeding the limit set. Id say you have noise problems.
Maybe post some pictures of your setup?
Bennem
Tue Jun 10 2008, 05:50AM
Something dosn't sound right with your OCD.
When the OCD pot is turned fully in one one direction,
the OCD light will fully come/ stay on.
When adjusting it after that point, the LED should go off
and it only flickers on when the over current peaks in your
primary reach that desired cut off point.
so....the LED dosn't vary in brightnes...its either on (flickers at cut off)) or off.
As Steve said....perhaps you have noise issues with your OCD circuit?
AS to your swopping Primary connections causing your IGBT's to get hot,
i'm at a loss about that.
Are you using a Half bridge or full bridge of IGBT's?
Mel.
Tom540
Tue Jun 10 2008, 03:29PM
Tom540 Banned on 3/17/2009.
How about post a pic of your boards and layout?
Tue Jun 10 2008, 06:11PM
Looking again, the second scope shot you show looks like you must have the feedback backwards because the gate transition is LEADING the red trace (which im assuming is maybe the primary current?). This would be caused by negative feedback, whereas you need positive feedback. What is the frequency of the switching in the second scope shot? I bet its far higher than you may have anticipated? It also would explain any severe IGBT heating.
Ken M.
Tue Jun 10 2008, 09:01PM
So yea looks you wer right Steve, i switched the feedback and decided to be stupid and try and see if I could get the secondary to arc to my finger...It produces HV but maybe only 1k if that.
Here is a wide shot of my setup ATM, the primary is all over the former because its the way I was able to measure 200some volts pk-pk on the secondary, But I tightend the primary and moved it to this position(right).
1213130680 618 FT46866 Sd530628 1213130995 618 FT46866 Tc Rotate
I'm using a 1/2 bridge right now since I only have enough gator clamps for 2 igbts, and since fixing the Feedback to positive feedback..the igbts get hot and in a hurry so I mounted them to some heatsinks till I get his to pump out some decent arcs, anys i got a better scope shot of the primary, The red (ch1) is measuring the feedback after teh inverters just as its going into the Fet driver, and the yeelow (Ch2) is measuring the point where the 2 igbts connect and go to the mmc and the primary.
Also just a breadboard shot.
1213131198 618 FT46866 Sd530630 1213131580 618 FT46866 Sd530639
I realize that the original design said the primary was below the secondary, so I thought perhaps if I moved it down, to the top of the duct tape it might allow the primary to resonate and the secondary produce more voltage, but it doesn't it just decreases arc output.
So Anyone still got any ideas as to how to adjust this to push out more power without stepping up voltage, or any other helpful advice?
Tue Jun 10 2008, 11:41PM
Build your bridge onto a circuit board. You have so much extra inductance and resistance everywhere that it will never give much performance in its current state.
