  • Guests: 65
Cool transformer!!
Patriot
Thu Jun 05 2008, 04:03PM Print
Patriot Registered Member #1507 Joined: Tue May 27 2008, 04:05PM
Hey, if anybodies interested i found a pretty sweet transformer, might make a good vttc. Link2
If anybody knows, what the heck is an oven transformer??
[Moderator Edit: Combined double post]
Spedy
Thu Jun 05 2008, 06:29PM
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
Ok: Don;t double post. Just use the "edit" button.
I think the "oven transformer" is an OBIT, oil burner ignition transformer. I think they're normally found in older water heaters, but I might be wrong.
Patriot
Thu Jun 05 2008, 06:41PM
I would have thought it was a obit too, but those usually put out in the tens of ma range and there pretty small. This one puts out 500ma at 5000v and is 40 lbs. And obit's are current limited like an nst, this has none, like a mot.
cjk2
Thu Jun 05 2008, 08:09PM
Maybe from a commercial microwave? or a radar transmitter for example?
Patriot
Thu Jun 05 2008, 08:19PM
commercial microwave.....it would kinda make sense. hmmmm?? the mystery continues
MOT_man
Fri Jun 06 2008, 02:02AM
I saw one just like it igniting heavy oils for an industrial burner. This might just be one of those...
Patriot
Fri Jun 06 2008, 03:45AM
If it was just a little cheaper i wouldn't mind snatching it up. But i could get about the same performance with 2 mot's, oh well.
