  • Guests: 74
finding the inductance of a tesla coil primary
Avi
Tue Jun 03 2008, 06:53PM Print
original thread Link2
Are you planning to use this as a TC or something
yes (drsstc)
where it will be used with a cap as a resonant circuit?
yes
If so, do you have the cap you plan to use?
no, thats the point of this, to find the cap i need to get, i measured 30.1uH with the whole setup inside it (secondary and topload etc).
Measuring the true resonant frequency is more useful than knowing the inductance.
ive already got that, i measured the frequency that gave the highest output from the secondary (from a wire nearby), it was 262.5Khz
Anyway, I'd try again with a few different frequencies, preferably over a bigger range than 80-90KHz
my sine wave generator only goes up to 100Khz
Other things to worry about are distortion (does the 'scope trace look like a decent sine wave?) and loading; is the signal generator struggling to feed the load or is the scope loading it down?
With a measured impedance of just 28 ohms I think the former is more likely to be a problem than the latter.
true, i can not drive it at full amplitude or the wave is clipped and distorted, I turn the amplitude way down and it looks a pretty good sine to me.
Andyman
Wed Jun 04 2008, 05:09PM
Would it be possible to measure the inductance with a simple ohm/volt/amp multimeter?
Avi
Wed Jun 04 2008, 05:36PM
yes and no, you could measure the resonant rise with a known capacitor, that is if the meter works at all at such an insane frequency. i prefer to scope it.
I have yet to try this method although it would rely on complete faith of the printed capacitor value neutral
