  • Guests: 61
Mini Brute Logic Power Supply
Thu May 29 2008, 09:40PM Print
Registered Member #1415 Joined:
I recently completed the logic power supply section and tested it, but it wouldn't work. The green LED on the display board showed that the 15V supply was on, but the 5V failed to light. I then checked the 5V voltage regulator and it was extremely hot. I even tested the transformer and it gave 26 volts of AC. (that can't be the problem) What could of caused the 7805 voltage regulator to become extremely hot and not function? (I also had the earth ground line connected into the board from the plug and the transformer, so I am clueless as to why it won't work. Any ideas or suggestions would be helpful.
The schematic is here, its titled low voltage power supply.
Dago
Thu May 29 2008, 10:34PM
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
If the transformer is really giving out 26VAC then your feeding almost 37VDC to the regulator and its specced for 30VDC iirc...
Thu May 29 2008, 10:47PM
thats true
I guess the only thing to do would be to get a transformer with an AC output of like 15V, but I find it hard to believe that the Mini Brute parts list called for a transformer that gave too high an output voltage.
GeordieBoy
Thu May 29 2008, 11:13PM
Transformer output side is centre-tapped and each half is half-wave rectified. Resulting un-regulated DC to the voltage regs is in the region of 18volts, which is within spec for the regulators. I would suggest checking for shorts between the +5V line and ground as a starting point.
Fri May 30 2008, 12:06AM
Sounds like a short to me somewhere.
The 5V line doesn't pull much current to begin with, so even with say 18V input, its not going to get hot.
Fri May 30 2008, 03:45AM
thanks
I will check
Ultra7
Fri May 30 2008, 11:42AM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
Edit:
Nevermind, I'm mistaken.
