  • Guests: 55
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
Dual MOT Power Supply
Sam
Fri Mar 17 2006, 10:35PM
Sam Registered Member #227 Joined: Mon Feb 20 2006, 10:47PM
I have a nice 5 amp ballat but I guess You coul go a out and grab a 10 or 15 amp thing, I did get mine for free though... it is an actual ballat not a shorted xformer
Michael W.
Fri Mar 17 2006, 10:49PM
what is the cheapest way to make a ballast? and If I do draw too much current will a surge protected powerbar save me or am I at risk of killing a computer etc...
Sam
Sat Mar 18 2006, 12:01AM
I have a but load of old xformers out of old vcr's, home stereo's and all sorts of stuff, find a few high wattage xformers, short the side not intended for 120 and put it in series with the mots. it worked for me untill i found a low wattage one... poof! magic smoke! use a variac!!! no question about it.
note the secondary side wires get hot, really hot, go with a MOT.
GimpyJoe
Sat Mar 18 2006, 01:51AM
Go to swap meets and try to find an old arc welder. I have an old 70a hobby arc welder to ballast MOT stacks and it's perfect. You can even change the inductance.
Part Scavenger
Tue Mar 28 2006, 03:51AM
Ben, the secondary isn't supposed get hot. If it does, it means, I think, and don't quote me that your "ballast" is dropping voltage. Do this: short the secondarys to the core so that they become part of the core. Mine don't even get hot. You should see an increase in performance as it is now limiting current and not dropping (very much anyway) voltage. Anyway, just a thought, most people don't tell you to include the core. Hope that helps anyone.
