  • Guests: 16
  • Members: 1
sbs_2010 (34)
SoundDoc (50)
10/10 Ryan Parle (44)
10/10 paulj (29)
10/10 Golasekk (48)
Homemade spud gun.
Mon Dec 22 2008, 04:28AM
It is funny that you ask, as i pulled it out a few days ago. Anyway, no a battery would not help at all :). You need high voltage, and batteries are very low volage compared to what is needed. The higher the voltage, the longer the gap can be and the easier it will combust and it will give more complete combustion. A good voltage would be maybe 30,000 volts, and the highest available battery is only 12 volts. A BBQ igniter is pretty cheap and it works great. I made a new spudgun awhile ago, i guess i never showed it. It is small, portable, and very strong for how small it is. It will explode a full unopened coke can, if i use a little soft thing from the end of a badminton birdie and a spark plug as the main projectile, and i can blow a hole through a 1/4 inch piece of plywood. I will post the videos as soon as i have a conversion file so i can hook all the vid's together so i can put them on youtube. I will take a pic later though.
Hon1nbo
Mon Dec 22 2008, 10:54PM
a good ignition source that is cheap, easy to use, and compact is the piezoelectric ignition unit from an electric lighter... the gas grill kind are a little long to use and are not powerful enough to arc on their own without modifying the terminal postions, so you'd have to run the wire through a hole into the inition chamber... the piezo unit can be mounted in a small hole in the wall and still arc to itself ^_^
Tue Dec 23 2008, 04:19AM
Well, the BBQ grill igniter is piezoelectric. And what i did was simply cut a hole in on of the end caps(could just be anywhere in the combustion chamber) and put the igniter in it and glued around it to make a near air tight fit. I just used a piece of wire going from one of the terminals of the igniter and brought it about half an inch from the other terminal to make a little spark gap. It works nicely and every time as long as i have the right amount of gas.
rp181
Tue Dec 23 2008, 04:29AM
I did one with a 2L chamber, and a 1/2in barrel. It puts a 1/2 steel bolt (with head cut off) through 2 in. of wood.
Lakeowner
Thu Dec 25 2008, 01:52PM
Lakeowner Registered Member #1370 Joined: Mon Mar 03 2008, 09:01AM
I'm working also on a spud gun. I have done a pneumatic gun which was used at 8bar. It has about 15mm wide metal tube and shoots AA batteries. Friend shooting in 2007:
1230212648 1370 FT46011 Timo Ampuu 1
Now I have a 1000x50mm polypropylene pipe for shooting various stuff with pressurised air. Also propane/butane gas would be nice to test.
