  • Guests: 51
voltage booster
Solidacid
Mon May 26 2008, 02:17PM Print
Solidacid Registered Member #1430 Joined: Sun Apr 06 2008, 11:12AM
hey all.
i recently need a 0-1000v powersupply so i built "the powerlabs flyback driver" to drive a custom coil to get pulsed DC a the same voltage as the input. it works really well, i tried making a coil and soldering an LED onto it and when i bring the two coils near each other the led lights up.
now, my problem is: i tried feeding the pulsed DC to a reversed 9-230v transformer, i slowly turned up the inout voltage, but when the output voltage reached about 25v the clip leads attached to the transformer started buzzing loudly and the voltage dropped to 0. i turned the knob on my powersupply back a tiny bit and i was getting 25v with no buzzing again.
can anyone tell me what is going on?
cjk2
Mon May 26 2008, 03:46PM
You're probably saturating the core. Try using a ferrite core rather than an iron one in that transformer.
Solidacid
Mon May 26 2008, 04:23PM
saturating the core? could you explain that in detail?
i think i know what it means
Mon May 26 2008, 06:03PM
maybe this can help you
