  • Guests: 44
Question about 'Geek Group' capacitors.
Sat May 24 2008, 08:36PM Print
I am still in need of some good quality high voltage caps for my 12kv 60ma transformer tesla coil. On gravitymagnet.com they had a chart saying for a 12kv 60ma transformer for ltr capacitor i should use 8 in series. That would be great and all but the voltage would destroy it wouldn't it?I figured i should use 14 per string and 2 strings. The ac rating for those capacitors would be 1kvac, right? If so it couldn't stand more that 8kvac. There is no way this could work(for long).
Here is webpage: Link2
Sat May 24 2008, 09:54PM
In my experience, the single string will work, but the longevity is questionable. Definitely go with 2 strings of more caps if you can afford it, it will not only last longer, but probably survive any mistakes you make.
Sat May 24 2008, 10:56PM
Wow, looks like i need to make alot of money.... Around 200bucks. If anyone wants to donate feel free! Kidding...again...
Would anyone suggest doorknobs over other capacitors if your on a tight budget? I found some cheep 30kv 4700pf capacitors(doorknob) and i am going to buy them if the guy starts a new bid for more on ebay. But i do not believe he is. So i am stuck. I am building uzzors's palm sstc after i get the capacitors for the sgtc, so please don't suggest i make sstc. I already have one running of my design so i do have something working out for me. ;) wink
Hazmatt_(The Underdog)
Sat May 24 2008, 11:50PM
Not if the Doorknobs you're attempting to buy are Spragues. Sprague Doorknobs are Mica and are not suitable for TC work unless you plan on <300W.
You have to measure each Mica cap because they will not be the face value. A 4000pF cap may be as low as 1800pF, which means its on its way out!
The guy I bought my Spragues from a couple years back just destroyed his PT because they shorted during one of his runs. Bill even asked me if he could buy the PT he sold me to replace the one he blew.
I was a bit lucky in comparison to Bill, I only killed a brand new 12/60 Franceformer, still cost me $200 though.
So you have been warned. Micas are for DC blocking, not pulse. The will work to an extent, but once they're dead they kill your supply too.
Id go MMC.
J. Aaron Holmes
Sat May 24 2008, 11:52PM
Arcstarter wrote ...
The strontium titanate RF dooknobs might do ok. I've heard of people using those in SGTCs. The usual problem with doorknobs is overheating and literally "frying", AFAIK. These days, they're mostly considered fodder for Marx generators and VTTCs. A friend of mine built a HUGE MMC out of more than 100 of those little 500pF Sprague mica doorknobs (usually green in color) and attempted to use it with his pole pig coil and ARSG. He was blowing a cap every couple of seconds and evenrually decided he'd better stop and save the rest for some other non-Tesla project.
Of course, nothing is "cheaper" if it immedialy blows up. Then you're back in the same place you started from with a negative balance! dead
EDIT: Hehehe...funny...Hazmatt jumped in while I was typing the above...guess that's two strikes against the Spragues!
Cheers,
Aaron, N7OE
teslacoolguy
Sun May 25 2008, 12:25AM
At this point the cde sampling service is going to be your best friend because they will send you 10 free caps therefore saving you about 30 bucks but hey 10 is better than nothing.
Sun May 25 2008, 01:08AM
teslacoolguy wrote ...
Oh, ok, that is how it works! Can you tell me how to do it? Thanks everyone from saving my money by telling me what not to use :). And thank you teslacoolguy.
Update: Apparently the 942C20P15K-F are only rated for 500vac....
J. Aaron Holmes
Sun May 25 2008, 02:17AM
That's well-known. They are quite underrated.
Cheers,
Aaron, N7OE
teslacoolguy
Sun May 25 2008, 03:05AM
here is the cde sampleing link Link2
Sun May 25 2008, 04:03AM
J. Aaron Holmes wrote ...
Cheers,
Aaron, N7OE
Really? Yet they stand up to it? Well you guys have had good experiences so i have already ordered some. Now i just have to buy 100bucks worth. :'(
And teslacoolguy, thanks alot!
