  • Guests: 44
pic or avr programmer?
Solidacid
Thu May 22 2008, 09:05AM Print
Solidacid Registered Member #1430 Joined: Sun Apr 06 2008, 11:12AM
hey all.
i recently got interested in microcontrollers and now im wondering if i should buy a pic or an avr programmer or even better, build one myself. if i want to program simple things like electronic dice and led flashers and such, what chips should i use?
Bjørn
Thu May 22 2008, 09:59AM
Use Picaxe: Link2
It can't get any simpler or cheaper.
reign
Thu May 22 2008, 11:18PM
reign Registered Member #260 Joined: Sun Feb 26 2006, 09:51PM
You may also want to give Arduino a shot. It's based off of an Atmel AVR.
Avi
Fri May 23 2008, 01:16AM
link seems to be down
Solidacid
Fri May 23 2008, 07:05AM
Bjørn Bæverfjord wrote ...
Use Picaxe: Link2
it says on the site that you need 95, 98, ME, NT, 2000 or XP, i have vista :P
and i don't have a seriel or parralel plug on my computer, only usb
Bjørn
Fri May 23 2008, 10:42AM
According to this it should work fine:
"All the software described above is for Windows operating systems (95, 98, ME, NT, 2000, XP, Vista) "
"USB Download Cable (part AXE027)
(Vista / XP users - ensure you are using the correct XP specific driver (also valid for Vista), available from the software page at Link2)"
Remember that XP and vista shares the same driver model so almost all XP drivers will work on Vista as long as they are correctly written. Just bypass those horrific install programs and find the XP .inf file and the driver files and install from there. Then devices like 10 year old 3Com network cards and Canon LiDE scanners will work without any problem.
In addiftion there are probably USB <--> RS-232 converters that will work fine.
Capper
Fri May 23 2008, 12:37PM
Capper Registered Member #914 Joined: Fri Jul 20 2007, 06:22PM
Once you start playing with micros, you'll find that both Microchip and Atmel have good products. I've used both, and it's nice to have the choice when you need it - so you may want to invest in both programmers.
The AVRISP MKII USB programmer for Atmel parts works the best for me ($36 at Digikey part number ATAVRISP2). I have a Dragon, and a STK500, but only used each once, and only purchased them because Atmel had a special 2-for-1 sale.
I use the MPLab ICD2 for Microchip parts. The cost was about $100 with a Circuit Cellar contest coupon.
There are a lot of available demo boards out there to play with for either manufacturer, and everyone is getting into the design contest game - so check their forums and web sites for deals on programmers, demo boards and such. Some give out free ones if you enter their contests. Renesas is running one right now.
I will say that the AVRFreaks forums are more helpful than the Microchip forums, but there are some embedded system forums that will help you with either chip set.
The programming software for Atmel is all free (AVR Studio, WINAVR), the free C compiler from Microchip is only a "student" version with some limitations. Stay away from Keil uVision if possible - I've had the most problems with their software, and the full versions are very expensive.
For the hobby group, parts in DIP packages are nice, and Atmel has more selection for 40-pin parts with lots of I/O pins. Microchip has some 28-pin parts that are faster with configurable I/O pins, and they will send out samples without a vendor calling on you.
So.....
Check the forums for contests with free demo boards and coupons for discounts on programmers, then just pick one and start programming. There really isn't too much trouble switching back and forth, and most of your code that's not hardware specific will work with both compilers.
Have fun.
Scott
Tue May 27 2008, 06:04AM
I started out with Atmel AVRs and found it very easy (and relatively cheap) to get going. After over a year of using AVRs, i used a dsPIC for a project, i found the documentation for the PIC stuff to be awful compared to the AVR. The PIC had some performance features the AVR didnt, though it did cost more (nothing special there). In general i look for an AVR that will work first, if it doesnt exist i look elsewhere.
GeordieBoy
Tue May 27 2008, 09:39AM
The dsPIC is quite a leap from the normal 8-bit PICs though Steve. It helps if you are already familiar with DSPs if that is the route you want to take for your application. I have used dsPICs for commercial, research and hobby projects and have also found the documentation quite heavy going.
Dr Who
Fri Jun 13 2008, 09:34PM
Dr Who Registered Member #1540 Joined: Fri Jun 13 2008, 08:49PM
Well I started off with a Sharc DSP and would absolutely not recommend that to anyone starting out for the first time. I then got involved with the AVR's and they seemed like a piece of cake. I got a little involved with Steve's dsPic and I gotta say that documentation is confusing as all get out. In fact, the Sharc was actually easier suprised
I think I was using the STk500 when playing with the AVR's? Programmer's Notepad and this website will get you rolling real fast:
http://www.nongnu.org/avr-libc/user-manual/index.html
Btw, I wouldn't recommend building your own programmer at first. There are always going to be quirks with the micro you choose and it's already hard enough to get things working with hardware that you know should work outta the box. Besides, it's not like you're going to gain any convenience by making your own...especially when you don't know what features you might want in your programmer...
