  • Guests: 44
Arizona Tesla Coil Builders 'Secondary Winding Lathe'
Dr. Drone
Wed May 21 2008, 01:49AM Print
shades
Ultra7
Wed May 21 2008, 01:56AM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
Oh man is that ever cool. suprised
Does it play the death metal as it runs, or do you have to add that in separate?
Reaching
Wed May 21 2008, 01:34PM
nice. is it really that slow or was that the first gear? :P
the motor looks powerful..
Dr. Drone
Wed May 21 2008, 03:54PM
shades
Alexandre
Wed May 21 2008, 06:47PM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
showww
Coronafix
Wed May 21 2008, 11:10PM
Awesome winder! Somewhat more advanced than the one I built recently by pulling the trigger out of a cordless drill and building it into a foot pedal. :) Works well though.
Love the doom though, sounds like Disembowelment. (The band not the action)
teslacoolguy
Thu May 22 2008, 02:01AM
Man did i need one of those when i was winding my 6" coil
quicksilver
Thu May 22 2008, 02:24AM
There is a foot pedal for a wood lathe that is occasionally used in a variety of wood-working applications (I haven't seen it sold outside of that environment) that MAY be much more sophisticated that a "dimmer-switch" concept. It's rather expensive at $39 but does superficially appear to function within a "non-stepper" motor unit not specifically designed for variances in speed..
This same concept may also be used in certain sewing machines (higher cost however). If this is actually applicable to various motors it would make coil winding MUCH more customizable for the individual who doesn't want to invest in custom design for two or three coils, etc.
Coronafix
Thu May 22 2008, 10:50AM
I don't often post any pics of my projects and you can probably see why, but I thought this might be of use to people out there. What I did was take a 18V cordless drill, pull it apart and take out the trigger and attached TRIAC. I extended the wires between the switch and the motor so I could put the switch down into a dodgy built footpedal.
I run the whole thing off a variable voltage power supply that I built.
The black thing on the coil shaft is a piece of wood that I sanded into a cam and has some foam on it. This triggers a manual counter every time the coil rotates thereby counting the number of turns.
It's all very basic, but it works. A simple solution to Henrys beautiful creation.
1211453362 160 FT45700 18v Winder
1211453362 160 FT45700 Footpedal
Thu May 22 2008, 04:58PM
I have a similar setup using a 3 phased motor controlled through a frequency inverter, but at low speeds the motor gets too little cooling from its fan.
is this a problem with your winder?
