  • Guests: 57
Help with tesla coil.
Tue May 20 2008, 05:17PM Print
I had 6 inch sparks with a 6kv 30ma nst and now i have a new 12kv 60ma nst and the sparks ar no more than 4 inches. The nst is providing what it should be but i don't have any good capacitors. I don't even know what capacitance i am at now. I have a transparency capacitor, a mylar capacitor and a very small mylar capacitor. No matter what i can not get good performance with it. I am tired of this. I believe it is because either my caps are extremely lossy or i don't have the right capacitance. I don't have the money for good capacitors so i need to know why this is happening. I keep adding a party cup capacitor or two and it decreases the noise of the rsg, suggesting that it is too much capacitance. Well i am off to get get another piece of mylar to make another capacitor :'(.
teslacoolguy
Tue May 20 2008, 05:45PM
I would ditch the whole idea of making party cup caps because they are very lossey and unrealiable. Get some beer bottles and make beer bottle caps because they are much more reliable and the average capacitence is 1.5pf per cap. Also try to play with primary coil a little.
J. Aaron Holmes
Tue May 20 2008, 05:56PM
teslacoolguy wrote ...
...and the average capacitence is 1.5pf per cap.
You mean "nF", not "pF" wink
Cheers,
Aaron, N7OE
Tue May 20 2008, 06:48PM
Well glass is lossy too. Well someone down the street from me has a few big plates of glass so i would rather get that. Sorry mike but i tried the party cup caps on the flyback and they are constantly sucking power out of it, meaning it will get hot(cause it did) and will suck more power than necessary(which it did). Plus i have seen some good glass plate caps, even though the are heavy and stuff, but they are so thick that i doubt they will ruin for a LONGG time.
Ultra7
Tue May 20 2008, 10:58PM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
No worries. smile
marko666
Thu May 22 2008, 03:24PM
marko666 Registered Member #1489 Joined: Sat May 17 2008, 09:38PM
Hi,I have a 12Kv 60ma NST too.I use 3 maxwell pulse caps adding up to 90 nF.They are in paralell. From this I get about 24 inches of arc
1211469862 1489 FT45658 Caps
J. Aaron Holmes
Thu May 22 2008, 03:48PM
marko666 wrote ...
Hi,I have a 12Kv 60ma NST too.I use 3 maxwell pulse caps adding up to 90 nF.They are in paralell. From this I get about 24 inches of arc.
Wow, why so much capacitance? suprised confused angry That's about 6x as much as you probably should have. I don't doubt that it's seriously hurting your performance by keeping your firing voltage low. "More is better" cannot be universally applied in Tesla coil design! With a 12/60 NST, you ought to be able to get 40+" streamers without much difficulty. Having wayyyyy too much cap in a small coil is also going to force your hand on the primary design to the point where you'll probably have far too few primary turns, which adds up to very high primary currents and increased losses in the spark gap.
Cheers,
Aaron, N7OE
MOT_man
Fri May 23 2008, 05:55AM
If you had 5 paralleled 12kV 60mA NST units then sure - I might just go with 90 nF worth of capacitance. I'm using 3 paralleled 12kV 60mA NSTs and I'm breaking 62.5 nF now... If your cap is too big then the caps won't charge in time and you'll get too low a voltage in gap. If the cap is too low in value then you'll blow the trannies up! Your coil has to be in balanced and phased correctly!
Hazmatt_(The Underdog)
Fri May 23 2008, 07:41AM
my calculations are 1.5x resonant. If you're interested in where I get that factor ( root(2) to 1.5) its on the fourm as ~ LTR calculations. That will give you maximum output. you should get ~32" from a 720VA transformer.
Sat May 24 2008, 08:00PM
Ok, i made 4 transparency capacitors and they equaled up to 16nf and i got mabey 4 inch streamers. }:(
