  • Guests: 71
RoV IW3IPD (63)
01/13 si2030 (62)
Rectifying my NST?
Mon May 19 2008, 11:07AM
wrote ...
Yes, well, 10.5kV peak rectified from 7.5kV rms.However, if you've got both a +ve and a -ve output from the rectifiers, you will have 21kV between the two outputs.
Yes, but whatever equipment you'll be running / testing will need to be isolated / floating from ground.
Quantum Singularity
Mon May 19 2008, 02:25PM
Backyard Skunkworks wrote ...
You can get the 1N4007s WAAY cheaper then $8 for 100, I got 500 for $8 from mouser. Radiosh** charges like $0.25 each or something...
Things might be just a tad pricier in Australia...
lpfthings
Sat May 24 2008, 02:13PM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Yes lots of stuff is more expensive here. BTW i did get the lid for my resin block, i was just wondering how you got the "lid" off to reveal the windings? Grinded it off?
Sat May 24 2008, 08:40PM
I didn't reveal the windings. They're potted in resin that's impossible to remove. I think the piece of plastic that carries the terminals is stuck to the resin too.
