  • Guests: 78
PIRANHA-III
Terry Fritz
Thu May 15 2008, 05:38AM Print
Hi,
Now that many are playing with high power SISGs cheesey , there is no longer any worry about the PIRANHA-III.
I never developed the dual MOT thing past the theory, but I sort of knew what I was dong back then shades
The schematic is here. Just use a big variac to run off 20A 120VAC. I was working on a solid-state power controller too but that never got far.
The microsim file may need the diodes redefined and the breakdown voltages set to like 30kV to get it to run:
A little sketchy, but that is where it was back then and it looked fine.
I lost interest and went on to other things so It all pretty must stopped there. But if you have any questions, I can probably figure it out still wink
I knew it would take a year to catch on... It might take another year for the ball terminal tongue
Super busy here these days, but I see that after 18 months, 'modern' technology is catching on!! cheesey
Best Regards,
Terry
Staff
Thu May 15 2008, 02:04PM
Staff Registered Member #1274 Joined: Tue Jan 29 2008, 08:55AM
Very nice!
Alexandre
Thu May 15 2008, 09:54PM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
amazed WOW WOW WOW amazed
Fri May 16 2008, 02:19AM
Sweet! You are my hero terry fritz! You can tell by the way i did not capitalize your name... mistrust
