  • Guests: 41
All stored transistors are dead! The killer: SGTC
Mates
Sun May 11 2008, 09:18AM Print
Hi guys, I’ve just made a very painful and expensive experience. I left my plastic box with my collection of power mosfets lying on the table (btw. as usually…). Recently I finished small SGTC powered by fly-back and played a lot with this small beast. Unfortunately, probably the RF and EMG pulses from this stupid little coil destroyed all the FETS in the box! They are all dead in a very funny way. By simple measurements using a multimetr all looks fine, but in reality they are all like half open. It means all the transistor conduct 1-3A between drain and source without connected gate.
The death list:
IRFPC60 – 4pc
2SK3304 – 6pc
In total 10pc of dead FETS without any effect…I hate the world cry
At least sending a picture of the killer in action…
1210497491 1025 FT0 Vajicko2
Coronafix
Sun May 11 2008, 09:50AM
Bummer Mates! Nice photo though :)
Sun May 11 2008, 10:16AM
Did you try shorting the gate to emitter then apply some collector voltage? This happened to me with some transistors, these things can hold gate charge a for a long time.
just to give you some hope... neutral
Mates
Sun May 11 2008, 10:32AM
Plasmaddict wrote ...
Nice try but it didn't work. Now, I can use the transistors only as non-inductive power resistors mistrust If somebody has a use for such componenets I can produce them in large scale wink God, I'm so angry!!!!
Dr. H.
Sun May 11 2008, 11:57AM
Hi Mates
very unpleasent indeed. I had simmilar experience with my SSTC (I destryed the same way 4 X irfp460 frown. Otherwise nice looking coil.
Sun May 11 2008, 12:10PM
Thanks for the headsup, I better clear the worktable of sensitive components before starting up my first coil.
Electroholic
Mon May 12 2008, 09:39PM
The gate dielectric probably got messed up, thats why i always wrap my fets/igbts in tin foil for storage.
Andyman
Tue May 13 2008, 09:48PM
Dang, that sucks massively!
I have this electronic game in one of my plastic storage drawers (no idea why it's in there), and every now and then when I turn off my mini magnifier coil, the game will randomly start up. The drawer is about 8" from the cord running to my power strip, so there must be a pretty big RF field around the power cord. I even have a line filter, but it still does it sometimes. There must be a tiny EMP that occurs when I suddenly switch off the coil which is just big enough to create a voltage on the transistor that turns the thing on.
Rarely, the garage door opener light will come on as well. suprised
Backyard Skunkworks
Wed May 14 2008, 06:16AM
Wow... thats seriously brutal cry
Two words: Faraday Cage.
Avi
Wed May 14 2008, 12:27PM
So, does anyone have any tips on how they personally store their components against this?
