  • Guests: 50
high voltage snubber?
Solidacid
Fri May 09 2008, 03:55PM Print
Solidacid Registered Member #1430 Joined: Sun Apr 06 2008, 11:12AM
hey everyone.
i have built this coil driver:
Coildrv
and i works great but only for a while. when i use it sparks get shorter and shorter over time(3 minutes) until it almost cant spark. i think my 555 is being killed by back-emf(i can feel a constant shocking/tingling sensation when i hold the leads onto a 9 volt battery) i read somewhere that a "snubber" would stop the back-emf from getting to the 555 chip, can you help me build one?
maybe you could even make the driver and the coil to run on seperate power sources?(that would be great)
EDIT: i forgot to say that im running this thing no a 9volt battery
Fri May 09 2008, 05:18PM
Solidacid wrote ...
Your 9V battery is discharging, this circuit pulls fair amount of currents which discharges the little battery in a few minutes. Get a better power supply with 12V and at least 4A.
Solidacid
Fri May 09 2008, 06:51PM
the spark gets shorter if i use an AC power supply too
Fri May 09 2008, 06:58PM
Solidacid wrote ...
Well, this is absolutely weird. I've never had a silicon component die like this, it either works or does not work. Are you absolutely sure? Can you try it again?
teslacoolguy
Fri May 09 2008, 07:02PM
Scilicon components dont die a slow death and any reason why you are using a AC supply and not a DC supply.
Mates
Fri May 09 2008, 07:23PM
Actually old NPN transistor can die by a slow death when are heat over-exposed... I have this kind of experience...do you have a heat sink?
Solidacid
Fri May 09 2008, 07:46PM
i meant i was using a DC power supply plugging into AC.
i tried several times (7 to be exact).
as soon as i change the 555 it sparks at full power again.
the transistor doesn't get hot.
EDIT: there must be some back-emf going on because sometimes the negative battery lead sparks to the battery casing
RE-EDIT: DAMN! i broke my mouse playing with this thing angry suddently windoze informed me that "my mouse was no longer responding"
Antonio
Sat May 10 2008, 12:26AM
The tingling sensation is because the high voltage at the output creates an intense electric field around it, and induces a current between the circuit and you that is probably serving as ground. Ground the circuit as shown in the schematic at this will almost disappear. A snubber can be a capacitor across the transistor. Probably several tens of nF, rated to 250 V or more. A 100 Ohms resistor (big) in series with it may help. It will prevent excessive voltage over the transistor when it is turned off. Put a filter between the power supply for the coil and the 555 supply. A resistor with a few Ohms and a big capacitor to ground. It's also good to add pairs of diodes to ground and to the power supply at the pins of the 555 that go to the potentiometers. This would protect it if a spark happens between the pots and you when you touch them.
Sat May 10 2008, 09:59PM
I have had problems with this circuit, the 2N3055 seems to draw a bigger current than some 555 can handle, so I have a C547B transistor between the 555 and 2n3055 to ease the stress. (in my schematic I use a mosfet instead of the 2n3055, a 2n3055 fits fine, mosfet just give a tiny extra spark and work better a higher frequencies)
I posted my schematics and there is abit about the troubles I had with kickbacks.
here: Link2
Solidacid
Sat May 10 2008, 10:17PM
thanks for the feedback everyone :D, for some reason it stop getting weaker and it's workingjust fine now(max 10mm spark is fine not great :( ) i think i will try making a more powerfull driver soon so if you have any links or suggestions for drivers that would be great.
it's nice to know im not the only dane doing stuff like this :D
