  • Guests: 71
01/13 si2030 (62)
Experiments with piezos
Madgyver
Thu Mar 16 2006, 05:31PM Print
Hi, I have some piezo crystals siiting here:
Link2,50,0,0,1,0
If you read to the end of the small article read on:
So, how do you guys think I can mount these buggers? I want to be able to use them in Motors or moving parts, so I can measure stress on them.
Besides, any further ideas what to do with them? Maybe 3 axis accelerometer...?
dan
Thu Mar 16 2006, 06:02PM
dan Registered Member #223 Joined: Mon Feb 20 2006, 06:42PM
Damn those are some big crystals. As for mounting them I'm not sure. I guess that would depend on what you wanted to do with them. The PCB soldered to them seemed to work well for pushing force but I don't think it would work well for pulling force. Maybe two clamps on either end secured to the sides of the crystal.
I seen a tremor sensor in one of my project books I bought at radioshack. From memory it used a piezoelectric speaker. One end of a long board was placed on the speaker and the other end had a weight on it. The piezo and board was then sandwiched between two bricks to hold the board on top of the speaker. Apparently this sensor could detect foot steps near by or a train coming from miles away.
Thu Mar 16 2006, 06:44PM
The crystal resonant frequency of 107 kHz is TC range
in this thread we have Wireless Transmission Of Power
How about a wireless piezo-motor?
As a guide to size, my 6"dia 3 ft high 1800 turn TC is 95 kHz
For the receiver you don't have to use a TC-type coil
for moderate received power a ferrite cored inductor/transformer would be OK
with a big topload.
At such low power maybe a flyback transformer (no diodes) with a small capacitive topload?
I guess just a capacitive aerial direct to the crystal would work too
(other end to EARTH)
I'd definately make a quick seismometer too.
stop4stuff
Fri Mar 17 2006, 07:35AM
stop4stuff Registered Member #64 Joined: Thu Feb 09 2006, 06:25AM
there's a couple of postings on fieldlines.com about using piezos to make electricity from sound see here and here
Dr. Shark
Fri Mar 17 2006, 07:36AM
I have used piezos remotely similar to those for fine-tuning the lengh of a laser cavity. They are good for precicions things like that, but I think they would make rather poor linear motors, as the travel is limited to a few nm. There is a way to use them for rotary motors, this is done in high end camera lenses, see Link2 for example. I don't really know how this works though.
Otherwise, use them to generate insane voltages! Extrapolating from the tiny crystals in piezo lighters, you should be able to get more than 100kV out if you strike them hard(or heat them up quickly?). Build a miniature particle accelerator like the one descibed here Link2 .
Oh, and would you care to sell some of the crystals to me?
Oh, and forget about that sound stuff, for than you want the really thin piezos you find in alarm clocks. They can be used in reverse to act as microphones, in fact you can stick one straight into the mic input of your soundcard and convert, well, sound to electricity.
Madgyver
Fri Mar 17 2006, 06:08PM
joe doh wrote ...
The linear motor I had in mind, works the same as the rotary one. The piezo is used to create a standing wave in a resonator (a stick) which goes up and down. Then the hole thing is swinging one a spring like contraption from left to the right. Both movements (up/down and left/right) are not equal in magnitude.
Now think of this motion as a finger, trying to move a radio tuner button, by tipping on it. Thats how these motors work (sort of)
This also works in linear arangement.
joe doh wrote ...
Yeah, I get nasty shocks by just soldering them. Maybe I should try a BB gun on them wink
joe doh wrote ...
might be worth a try anyway, wouldn't hurt would it?
Wed Mar 22 2006, 07:40PM
Hi,
One idea might be to use a Peltier to heat/cool the piezos then store the energy in a capacitor.
-A
Omicron
Thu Mar 23 2006, 02:19AM
Where did you get them? They’re huge! As for experiments, I would make a TC using them instead of a cap. Where in the world did you get them!
Carbon_Rod
Thu Mar 23 2006, 02:29AM
Hmmm, they look like they would fit in a copper tube of a coil gun.
May look neat. lol =]
GimpyJoe
Thu Mar 23 2006, 02:34AM
you have a bunch, so maybe you could sacrifice a few just seeing how long a spark you can make with one
