  • Guests: 51
Fireballs and lightning from volcano in Chile.. ??!!!!!
Thu May 08 2008, 10:06PM Print
Hi all. This looks decidely other-worldly.
Has anyone ever seen the like? Almost looks like something you might see on a sci-fi movie, but is in fact genuine and occurring right now.
-A
1210284371 96 FT0 Volcanoupi 800x531
Bjørn
Fri May 09 2008, 12:31AM
I have never seen it as nicely as that. Flying ash in general can be quite efficient at generating high voltages.
Firefox
Fri May 09 2008, 03:56AM
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
That is absolutely incredible! I would guess that the hot ash particles rubbing together creates a huge static charge that you see being released in the picture, on the same basic principal of a Van der Graff generator.
Mates
Fri May 09 2008, 05:54AM
Maybe the heat and ash particles works as a huge condutor connecting the higher charged parts of the atmosphere and the ground...
Fri May 09 2008, 07:27AM
Interesting. Although in this case I think that the simpler explanation of ash particles rubbing together (after being ejected at high speed from a volcano) would generage the effects seen. The fireballs could be nothing more than hot gases igniting on contact with air, although some theories suggest that they might be caused by localised air breakdown (intense electrical field gradient + RF excitation by continuous lightning discharges)
-A
lpfthings
Fri May 09 2008, 09:42AM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Lots of pics of erupting volcano's have lightning around them, it i most likely the ash, but it may also be lightning from the clouds also, since the ashes and charges make a fairly conductive trail at those voltages.
rp181
Fri May 09 2008, 01:17PM
Looks like a giant brain :D
Chris Russell
Sun May 11 2008, 02:45PM
Chris Russell ... not Russel!
An excellent picture. Where did you find it? It would be nice to make sure whoever took the picture is getting credit for it.
I think Firefox has it right: that would be my guess as well, without doing any research on the topic. Ash from the center of the column is probably moving much faster than ash on the outside of the column. This is going to cause particles to rub against eachother, essentially creating a big VDG in the sky.
Noelle
Sun May 11 2008, 02:59PM
Noelle Napoleonic Powermonger
Registered Member #2 Joined: Thu Jan 26 2006, 05:10AM
That is an awesome picture.. I think that would be both amazing and a little scary to see in person.
Because this lightning is produced electrostatically and not due to temperature/pressure changes, there would be no thunder, correct?
Marko
Sun May 11 2008, 03:49PM
Noelle wrote ...
Hm, I don't think it's that romantic actually - I'm pretty sure there's thunder just with like any other lightning, together with other sounds produced by the volcano.
The pic is indeed amazing though. Anyone found more information on it? Looks like a quite long bulb exposure. And to me it looks that most if not all of those 'fireballs' are just incandescent ash at places where lightning passes through the ash column.
Marko
