  • Guests: 36
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
I made a solid state tesla coil.
Thu May 08 2008, 04:32AM Print
It was basically this: Link2
schematic but i used a 1nf capacitor and 4 6.8nf caps all in series for the timing capacitor and 50 volts for the input. For the pot and resistor between pin 7 and pin 2 is a 2.2kohm resistor. My secondary is 4 inch by 16 inch and 28gauge wire. Some 1000 turns. The primary is at around 6-10 turns now.
There is a tiny bit of breakout and the spark is a little more than half an inch. Still no tuning, and soon i will run on 120 volts half wave and the full wave rectified. This would be a great sstc for a starter.
flannelhead
Thu May 08 2008, 12:38PM
Any pics or video?
Fixed frequency oscillators of course aren't the best bet for a solid state tesla coil but at least they're stable and reliable. PLL is a good combination of a fixed frequency oscillator and a self-resonant driver.
Oh and you might want to clean the top post up a bit. Someone may not be able to understand it completely.
Thu May 08 2008, 04:04PM
Can someone explain hat pll is? I know that it means phased locked loop but i do not know anything about it tongue. Oh and by the way i am only good at fixed frequency oscillators tongue
I am not sure of the frequency though, i don't have a scope.
amazed
cheesey confused
MRacerxdl
Thu May 08 2008, 11:19PM
PLL its generally a oscilator with feedback on it.
You set some frequency to operate and if he gets other oscilation from feedback, he locks that interal oscilation to that its coming on that feedback. The detail is, When it got the fres of the coil it doesnt change so easy, and it makes better to stay in that frequency.
Sat May 10 2008, 06:46PM
Oh! Sweetage!
UPDATE: well a frew minutes ago i put it back together but now i am using 28 turns on a 2.5 inch plastic cup that goes inside of the 4 inch primary. I am using 50 volts(drops to 40) at an amp and the mosfet is cool enough to touch. I use a 1nf capacitor for class e(i guess that is a 'shunt' capacitor?) and a series string of 4 6800pf capacitors for a total of 1.8nf. Everything stays cold now so i am quite happy. The sparks are VERY hot(turns the 24-28 gauge tin wire molten, and burn the stuff outta my finger) and ground arcs are up to about 1inch. I will post a video tomorrow.
Dr. SSTC
Sun Jun 22 2008, 04:18AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
arcstarer the 555 isnt so good at driving the mosfet at these speeds maybe you should add a gate drive chip and go for half bridge
teslacoolguy
Sun Jun 22 2008, 06:16AM
A simple npn pnp driver using bd139/bd140 transistorswill work fine
Dr. SSTC
Sun Jun 22 2008, 09:09AM
ye or that
Wed Jul 02 2008, 06:44AM
I don't know why i never posted again... Anyway, i am only running about 250khz, so why would it not run a mosfet at that speed?
I am planning on upgrading to a halfbridge just to so how far i could push the 555 driver.. hopefully i can make a discovery. :)
Also when i get some bd139/140 i will implement that into it, for better driving, would that help?
Dr. SSTC
Wed Jul 02 2008, 08:12AM
Arcstarter wrote ...
yes i will because 250khz i still a high frequency to be switched by the 555's tiny signal, the bd139/140 will be able to turn it on and of properly
