  • Guests: 112
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Choke of a doubler
Alexandre
Thu May 08 2008, 12:00AM Print
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
I'm having doubts about the Choke of my Doubler. shades
the output is 8kvDC @ 200ma,
I use two MOT in the series to choke? wink
Thu May 08 2008, 01:18AM
Well ever since i said to use 2 mots, i learned that you should use 4 mots.. I learned that the mots further double the voltage to 16kv. Matthew is sorry.... frown
Alexandre
Thu May 08 2008, 10:50PM
4 MOT??????? Oh my GOD!!!!!!!! cry
Are you sure you need all this??? frown
Fri May 09 2008, 03:22AM
Tesla Brasil wrote ...
So i heard... Go to ebay. You can get an mot for 20 bucks............................................. ............
I already have 4 mots... two more to go then just capacitors.
If you don't use 4 mots than apparently BOOM! I haven't tested it with less or more or at all really.
Alexandre
Fri May 09 2008, 06:14PM
I believe that uses 4 MOT is because of tension, which already supports up to each MOT 4kv max, 4 in series would 16kv, excellent for the coil. cheesey
The peak of the source is about 11kv, 3 MOT would sure? tongue
