  • Guests: 57
Would this wire be good for HV?
lpfthings
Fri May 02 2008, 10:17PM Print
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Wire with lots of insulation for HV stuff isnt easy to come by around here, but basically i have some wire that looks like it may work. It's the stuff you use to hook your aerial to the TV (cant remember it's name, sorry). It looks like it has a fair amount of insulation, and seems to have a signle copper wire through the middle. Would this work on my NST? I just need some wire that wont arc through if they are near each other.
Fri May 02 2008, 10:28PM
Well i don't know how the insulation is but i know that since it is close it will arc through due to ozone after awhile. Also, it has some capacitance which will put extra load on the nst which means somewhat less power output.
Antonio
Fri May 02 2008, 10:40PM
This is probably a 75 Ohms coaxial cable, with a central wire and a mesh around. Look at the insulation around the central wire. If it is a kind of foam, and not a thick solid plastic, the cable is useless. Anyway, the safe way to make high-voltage circuits is to not let the wires touch anything. You can then use any wire. Just avoid sharp curves.
lpfthings
Sat May 03 2008, 12:19AM
OK, well the cable is the stuff they use for satellite TV, but same stuff i guess. It seems to be hard plastic around the central wire. The only problem i see is that would HV build up in the sheilding wire? I am just looking for a thick cable, for when i'm experimenting. if the wire is to thin, it arcs through, sets the insulation on fire and results in toxic fumes.
jpsmith123
Sat May 03 2008, 12:41AM
IIRC, some people are successfully using RG8-U coax cable at voltages as high as 40 kv dc.
Andyman
Wed May 07 2008, 05:11AM
Just get a bunch of vinyl tubing from your hardware store and put the wire inside. I've tested it up to 13 kv and I can hold the wire in my hand with only a teenie bit of corona.
Mates
Wed May 07 2008, 05:35AM
Andyman wrote ...
....I can hold the wire in my hand with only a teenie bit of corona.
Hand touch - that's "really clever" way of testing how good your isolation is mad
Otherwise you right - the PVC tubing will do the job, you can even adopt part of the protocol for this HV diode Link2 and fill the tube with oil...
Dago
Wed May 07 2008, 08:41AM
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
Andyman wrote ...
That sounds extremely dangerous, I hope you arent using a high-current PSU to do that...
johnf
Fri May 09 2008, 07:38AM
Since you are in Australia go to your local Dick Smith store or Jaycar and buy RG8 also known as UR 67 or RG 213 we use these cables at work up to 100kV make sure that you pair back the braid for several inches (12" for 100kV) so that the ends dont arc over.
If your PSU is DC remember that the cable is also a capacitor at around 100pf per foot so it can store a nasty charge after you have switched off.
Solid polyethylene dielectric only no foam filled low loss cables are suitable the above part numbers are the solid kind.
RG11 is also alright
quicksilver
Fri May 09 2008, 02:06PM
In the USA I've heard of quite a few people say that RG8-U coax cable worked well up to a point. You may have a good response with a NST because the central cable shielding is really quite well insulated and if you're not dealing with a greater level of current than 30ma it may be fine. The best thing is to test it and see. I was thinking of just the same thing.
But I would NOT test HV materials with my body. Aside from everything safety issue already mentioned; it's not that good of a test! I once saw someone use a "C" clamp test meter away from a cable that he had bent in a "U" shape and hold the meter out from the junction of the bend to test the shielding. There are much more effective ways of determining shielding properties of course. Actually since Australia has the higher current/voltage standard there may be some very good research published on the internet dealing with that subject from a variety of public or industrial agencies.
I've been shocked a few times in my life but the first time I really got one was determined to be my last. I had gotten complacent with the 120Vac in the USA & generally gotten zapped from stuff that was reduced by household appliances that acted with resistance so basically I THOUGHT that main current was pretty tame. I was also in my twenties and thought I was invulnerable.
The one day I backed into a poorly protected 240 input for a welder. It just hit my elbow....I think. I really don't remember much except getting thrown across a shop like Godzilla's old beer can. What I DO remember was that I could hardly catch my breath. I was 25 and running tri-athalons. I think today that would have shut me down & killed me.
I have too much respect for HV to touch test anything anymore. Once you get bitten by the REAL thing, the reaction is VERY different than you ever though it could be. Please ...be careful.
