  • Guests: 62
Why are primaries wound flat?
speakerguy79
Thu May 01 2008, 03:27AM Print
speakerguy79 Registered Member #1460 Joined: Thu May 01 2008, 12:45AM
On all the big tesla coils I see, the primaries are wound flat instead of cylindrically around the secondary. I would think the latter would give better coupling. So why the flat primaries and tall secondaries? Thanks!
Myke
Thu May 01 2008, 03:37AM
If they were wound in a helix then there might be too much coupling causing turn to turn arcing.
There are conical primaries though.
J. Aaron Holmes
Thu May 01 2008, 04:54AM
Plus, a cylindrical primary is basically an autotransformer; the unconnected end can reach voltages far exceeding the primary tank voltage, which can entice flashovers and other badness.
Cheers,
Aaron, N7OE
