  • Guests: 27
Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
12/18 LD LANGER (38)
XenoSonic Construction / Troubleshooting
1 2 3 4  last
Austin
Mon Apr 28 2008, 01:56PM Print
Austin Registered Member #1169 Joined: Wed Dec 12 2007, 09:16AM
As suggested by Daniel this Discussion is aimed at trouble shooting and discussing Daniel's new modulator.
Like I said in a previous post, I get no output of U53 or U4. Both of which I have changed twice. However i get a signal out of U3. I got the VU meter working great and it seems to be blinking to the music, however when I hook up J2 to the Tesla i get nothing.
pin 5 shows +5 volts and r10 is open, jmp1 is also at the "B end" of the jumper if that helps any.
Any ideas or suggestions would be much appreciated
Mon Apr 28 2008, 02:56PM
Austin wrote ...
Please re-read the instructions. In particular, you need to set your envelope gain as shown in Step 3 of the instruction manual. Pin 5 of U4 should be at least 6V or you won't get any output.
If you want to temporarily test the set-up using fixed pulsewidth output, you can simply remove R9. However, start operation with max pulsewidth adjust set to zero and slowly increase.
Also, you should make sure you aren't duty limiting and make sure that is set as well according to the instructions.
An oscilloscope would be quite helpful in your troubleshooting and setting your pulsewidth limits etc...
What are you using for an audio source?
Austin
Mon Apr 28 2008, 09:10PM
Dr. Shock wrote ...
Austin wrote ...
I am only getting about 6 volts out of the 9v battery, I think this could be why I am not getting +6volts out of pin5 of U4? the duty cycle is set to 15% and my audio source is headphone jack to my laptop computer.
Mon Apr 28 2008, 09:46PM
+6V is the input to Pin5. It isn't generated by pin 5, its generated by the envlope detector op-amp.
You likely need to increase gain.
Plus, if you disconnect R9, then it doesn't matter what you have a pin5 since thats basically disabled.
Austin
Mon Apr 28 2008, 10:00PM
Dr. Shock wrote ...
Forgive my ignorance but I want to make sure I understand you. In order to increase the voltage coming into pin5 of u4 I need to set my gain as described in step 3 or increase the gain by disabling volume envelope pulsewidth control I.e. remove R9.
If that doesn’t work do you have any other suggestions? Besides replacing the 9volt.
Again thank you for taking the time to help walk me through this.
Tue Apr 29 2008, 02:18AM
Yes. Step 3 shows how to set the gain. With nominal input, you should have about 7V at pin 5. If you can't get 7V, then increase your input signal, or change some of the gain resistors for that first op-amp.
Or disable the entire envelope control by removing R9. The circuit altogether is extremely basic - you should try to gain a full understanding of it - its really easy - just a few op-amps, and a 555 timer IC.
Replacing chips or 9V is not the problem.
Austin
Tue Apr 29 2008, 03:25AM
Dr. Shock wrote ...
I think people forget that this Tesla project is my first introduction into electronics. While I have learned a tremendous amount along the way there is still a lot that I don't know. There is no shame in asking for help when you need it, especially from the person who designed it. I would not be spending time on the forums unless I have tried every possible thing I could think of.
Again, isn't that why we are all here? Learning begins at every skill level.
Bennem
Tue Apr 29 2008, 05:48AM
Bennem Registered Member #154 Joined: Sun Feb 12 2006, 04:28PM
Austin For someone making the MiniBrute project an introduction into electronics
and successfully getting it to work must be commended!!
I haven't read Dan's write up on his XenoSonic , but i would think all your questions would be
great feedback for him as to testement that his book works,
and areas where it possibly can be written to help the average
hobbiest to understand more clearly.
so....although there may be frustrations along the way,
i'm sure you'll get it working Austin.
All the best,
Mel
Wed Apr 30 2008, 02:06AM
Austin wrote ...
Dr. Shock wrote ...
There is no shame at all and i am happy to help you or anyone else. I am merely trying to engage you to look beyond the schematic on the page into getting an understanding of how the circuit works stage by stage. Its pretty simple and just spending a few minutes will help tremendously in your troubleshooting procedure. And again, i can help you with any questions you may have about the troubleshooting or how the circuit works.
That being said, i will probably update the instructional manual to describe how everything is working together in the schematic.
Austin
Wed Apr 30 2008, 04:13AM
K im still stuck. I removed R9 all together and still no output (pin3) of U4. Pin5 at U4 is well above +7 volts. I checked pin 1 of LM393 and i get aprox 2.5 volts. Pin 1 of U2 reads aprox +5 volts although im not sure that it matters now that R9 is gone. U4 is also getting power at pin 8.
also if this helps, while i had some audio input going into the modulator i could not get the over duty cycle LED D51 to trip even while I was messing with R55
1 2 3 4  last
