  • Guests: 63
CRT screen sucker
dingo27
Sun Apr 20 2008, 08:55AM Print
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
Hi folks, i need quick advice... i have CRT screen just about to disassemble, and i dunno if i can safetly remove top sucker on CRT tube (the one supplied with HV from HV transformer)...
can anybody assure me i can put it down, or just cut cable out?
I dunno if there is some hole to "inside tube", so it will be bad when i get it down
THANKS FOR ANSWERS (hope you understand me :) )
Sun Apr 20 2008, 09:24AM
The suction cup scared me the first time too, I though it would "release" the vacuum from the CRT. However the CRT is completely sealed, and the suction cup can be pulled off safely. Just pinch it and twist it off.
lpfthings
Sun Apr 20 2008, 11:17AM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
If your scared of taking it off, just cut the wire! thats what i do, then i dont have to worry (to much) about discharging the CRT tube....
mikeselectricstuff
Sun Apr 20 2008, 11:18AM
You might want to discharge it first if it's been powered up any time recently - clip a lead from ground ( usually a wire held in contact with the outer coating on the CRT to a thin screwdriver, then slip the screwdriver under the cap til it makes contact with the electrode in the middle.
dingo27
Sun Apr 20 2008, 12:44PM
it was powered apx. 14 hrs. ago, so i cutted wire, now i have HV transformer right in front of me :) thanks again
hope it will be good for my TC amazed
