  • Guests: 45
Party cup capacitors. Has anyone used them on tesla coils?
Fri Apr 18 2008, 03:56AM Print
Thanks to Ultra7,I have now decided upon using party cup capacitors. So has anyone had any experience with them? Im sure they would work well because they are the exact same thing as saltwater capacitors. I have tested mine at up to 20-30kv dc with my flyback without a single failure. They should be exposed to some 16kv peak on what i am using them for. I am using two mots with a doubler and then 4 mot's as a choke. I do not want to have to use more than 50 capacitors.
Also,about what would the capacitance be for a cup that is made from Jack Frost and is 16 ounces or 473 ml? The physical dimensions are 4 3/4 inches tall, 3 1/2 inches wide at the top and 2 inches wide at the bottom. None of the measurements are exact,but close.
Thank you! cheesey
Ultra7
Fri Apr 18 2008, 02:24PM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
Yeah, I used them before I got MMC caps.
No issues with them whatever but the mess.
It was fun building them with my kids, as well.
I'll post pics of them later.
Mark said with 10 cells, he got 5nf rated at 50KV.
So with 4, ten cell units, you'd get 20nF rated for 50Kv
That would be a peachy capacitor.
Add another 4 units in series for 40nF.
flannelhead
Fri Apr 18 2008, 03:52PM
Huh, that'd be a lot of work. It would take up a lot of space, too. I will probably prefer commercial caps for my coils.
Fri Apr 18 2008, 04:38PM
spark wrote ...
Well i posted a...post and noone told me were i could get commercial caps. Ultra7 suggested i used these because i am on a low budget (of approximately 0 bucks). If i can find some good caps for about 20-40 buck that can withstand 20kv and is 40 nf than i will be good!
flannelhead
Fri Apr 18 2008, 04:52PM
Look at ebay, you can often find plenty of good things... For example these: Link2 Link2
Ultra7
Fri Apr 18 2008, 06:17PM
Those 600 Volt caps probably wouldn't work, and the yellow caps are $3.50 apice
Arc is broke like a teenager.
I was giving him options to "make" a cheap cap rather than spending money he doesn't have.
J. Aaron Holmes
Fri Apr 18 2008, 06:33PM
spark wrote ...
Wow, $3.50/piece for nameless Chinese caps when Richardson sells the CDE942's for $2.87? I'll pass. Granted, the minimum order from Richardson is 50 pieces, so that's ~$150. I'll still pass.
Cheers,
Aaron, N7OE
Fri Apr 18 2008, 07:01PM
How about this capacitor? It is rated a little low on voltage but do you think it would be good for tesla coil duty? Because if i have to i will just use two mots for 4kv and use a ballast until the capacitance is right.
J. Aaron Holmes
Fri Apr 18 2008, 09:07PM
Arcstarter wrote ...
Hard to say. There isn't enough data there to convince me that it wouldn't just pop.
When you start thinking about trade-offs like this, it usually helps to have some kind of performance goal in mind. Then you can work backwards through the various formulae to determine what parts will get you there. 4kV with a .03uF cap is only 120W coil power at 120bps on the gap (about 1J/bang). That might make ~18" streamers if your quench is good, but at 4kV AC I'm going to bet against you unless you're building an RSG. Is this what you're looking for? If not, perhaps we can help you to explore other options. Just focusing on the cap may not be that helpful.
Cheers,
Aaron, N7OE
Ken M.
Fri Apr 18 2008, 09:11PM
The old Beer bottle caps work ok also >.>
