  • Guests: 43
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
No limits to DRSSTC
1 2 3 4  last
Dr. Drone
Wed Mar 15 2006, 03:47PM Print
shades
Wed Mar 15 2006, 03:59PM
Well, if there are limits, I'm sure you'll find them first wink The only one I can think of is "Less Than One Primary Turn", but I don't imagine that being a problem even at 50kVA. There are the usual ones like "Wallet Size", "Backyard Size" and "Sanity" but most of us broke those a while back confused
Can you explain what you did to the power bus to stop the flashovers, and do you know what caused them?
Wed Mar 15 2006, 04:14PM
Christopher Robin wrote ...
Good day,
The 10KWatt DRSSTC is backup and running. I was at 9 feet sparks when I had a flash over on the power bus on back of IGBT’s and blew the IGBT’s, gate driver, and a few TVS. Three weeks later and a new design on the power bus, I now have sparks again. Will continue to work on getting longer sparks and add pictures to the website. Thought you would enjoy that there is no limits to DRSSTC as now working on a 48KWATT DRSSTC! Website for the 10KWATT DRSSTC can be found at
Sure love DRSSTC’s indeed!
1142437548 290 FT0 10kwattdrsstc
How much power are you running for the 9 foot arcs? Seems like 10kW is a lot of power for only 9 foot arcs. But then again, it is proportional to duty cycle. You can run very low duty cycles and get big arcs from relatively low power levels.
Also, how are you planning on quantifying that your DRSSTC is putting out 48kW? Are you going by input power alone, or actually measuring power (rms) running through your bridge circuit?
Dr. Drone
Wed Mar 15 2006, 05:37PM
shades
Wed Mar 15 2006, 09:52PM
Outstanding....the first word that come in my mind.
Dr. Drone
Thu Mar 16 2006, 04:34AM
shades
Dr. Drone
Thu Mar 16 2006, 04:53AM
shades
Thu Mar 16 2006, 05:46AM
holy crap amazed How much are you planning to spend on this monster?
Good luck!
Thu Mar 16 2006, 12:06PM
When you say it's a 48kW coil: Is that just because you have a 200A 240V feed at the venue, and 200*240= 48000? You won't have unity power factor, in my experience the power factor of a single phase rectifier is 0.6 to 0.8, so you really only have 28 to 38kW available to make sparks. If you like big numbers, you can still call it a 48kVA coil.
I know it sounds like I'm being pedantic, but if you're going to build something this big, you need to understand all of these details clearly. It could make the difference between meeting your 25ft goal or missing it. Whatever, it's still a sh suprised load of power!
Dr. Drone
Thu Mar 16 2006, 01:52PM
shades
1 2 3 4  last
