  • Guests: 65
Need help with my SSTC
Ernestas
Mon Apr 14 2008, 05:59PM Print
Ernestas Registered Member #1443 Joined: Mon Apr 14 2008, 05:14PM
Hello.
I'm new in SSTC building. On my last experiment my Tesla Coil was working only about 10 seconds and mosfets were exploded. SSTC is Half-bridge. How i can protect the mosfets ? Across mosfet's Drain and Source are connected ultrafast diode and schottky diode connected to mosfet's drain. Will it be better, if I’ll connect TVSs between mosfet's Drain and Source? Or I connect bipolar capacitors across diode bridge output? What can You advice for me?
Sorry for my bad English.
Ultra7
Mon Apr 14 2008, 07:41PM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
Can we have a Schematic of your SSTC?
Mates
Mon Apr 14 2008, 08:25PM
10s is a good start. It looks you pumping to much of amps over your transistors. You should enhance the coupling by adding more turns on your primary. Proper cooling is also important.
TVS are always good part of any HV circuit, I even prefer paralleling of minimum two per transistor.
It's also important to have long and sharp breakout point and also tune your coil on lower volatge properly before you go on the mains.
More help you can get after you post your scheme...
Don't give up! wink
Ernestas
Mon Apr 14 2008, 08:37PM
PLL driver:
I used UCC's signal "amplifier", because I think UCCs haven't enough power to drive GDT and mosfets normally. Signal comes from UCC to this driver, and then it goes to GDT.
Half-Bridge (but I haven’t used gate resistors; my mosfets have internal zener diodes):
GDT form coilcraft - SD250-3L.
Now I'm going to use CT for the PLL feedback. Would it will be better than antenna?
Thanks, Mates. My mosfets are 29A, 500V. Secondary is 11 cm diameter and 38 cm height. Wire – 0,25 mm. Primary is form 3 mm wire, 6 turns. I’ll add TVSs across the mosfets.
Ken M.
Mon Apr 14 2008, 08:58PM
The UCC chips are the chips of choice, I'm sure everyone else here would agree with me. The standard 322 and 321 pump out 9A max each....more then enough to drive a GDT.
Ernestas
Mon Apr 14 2008, 09:11PM
UCCs are only 350mW, when my driver is more than 20W.
First of all, I have tried connecting my SSTC to 12V power supply. Sparks was less than 0,5cm and UCC were heating. When I soldered that amplifier and connected it, sparks were more than 1cm. Now UCCs only switching 4 amplifier’s mosfets. And that mosfets aren’t heating.
My SSTC:
Link2 (Sparks were more than 30 cm.)
Mates
Mon Apr 14 2008, 09:18PM
In case your UCC's are heating up than add more turns on your gate transformer...They should stay cold. Also six turns of primary could be your problem, since your fets exploded it looks like overcurrent problem...
Ernestas
Mon Apr 14 2008, 09:28PM
I can’t add more turns, because my GDT is form coilcraft (SD250-3L) or will be better, if I make my own GDT? But with that amplifier UCCs stay cold and mosfets on amplifier too. It look works perfect, but I don’t now, what are on and off times, because I haven’t oscilloscope.
Ernestas
Thu Apr 17 2008, 09:30PM
1. How power and voltage TVS I need for 500V and 29A diode ? Power supply for SSTC is 220V.
2. TVS connecting across mosfet drain and source with no more components ?
