  • Guests: 40
Underwater plasma globe/tube ?!
Mon Apr 14 2008, 07:20AM Print
Hi all.
Was looking at these beasties the other day and it got me thinking.
Given that water is more or less a homogenous conductor, what would happen if one were to seal up (using Polymorph etc) the driver board of a small plasma globe, glue and epoxy it to the base of the globe and then drop it into water?
Would the plasma globe continue to work normally?
Please advise.
-A
MOT_man
Mon Apr 14 2008, 07:30AM
yep --- I'm sure it would. Why not?
Avi
Mon Apr 14 2008, 08:29AM
maybe there would be more surface discharge?
Mon Apr 14 2008, 02:29PM
I believe this would have the same effect as putting your hand over the globe--you would end up with one streamer that goes to the glass, then spreads out along the surface.
When you load it down so that the entire tube is covered equally things might get a little different, but it would certinly be fun to try!
