  • Guests: 43
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Sounds silly, but would it work?
lpfthings
Sat Apr 12 2008, 12:42PM Print
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
I was thinking, since audio is AC, wouldnt just getting a high powered amplifier, and pumping the audio straight into somehting such as an ignition coil result in a singing arc? In theory it could work, but has anyone tried it?
Avi
Sat Apr 12 2008, 01:06PM
definitely not on an ignition coil, these are pulse transformers. You build up the magnetic field and suddenly disrupt it, resulting in a sudden collapse.
As for other types of transformers, they usually use the flyback effect to increase the voltage, they have a resonant frequency. To use them for audio you must either use the audio to cause the main oscillator to slightly detune (decreasing the intensity of the output voltage) or change the duty cycle, which would change the average power input.
lpfthings
Sat Apr 12 2008, 01:09PM
Well yeah, but if you could get a AC transformer, would it be possible?
Avi
Sat Apr 12 2008, 01:11PM
If you had an AC transformer rated for audio frequency, and the largest secondary you have ever seen, then perhaps.
eg: NSTS are rated for 50/60Hz and use 120v/240V to step to 15kv and they are quite large.
lpfthings
Sat Apr 12 2008, 01:15PM
Ahh ok, so really if it was that simple everyone would be using it. I guess if you could find a amplifier with 240V output it would work cheesey
Avi
Sat Apr 12 2008, 01:18PM
Not really, those transformers are designed to work for 50Hz/60Hz, the impedance would increase at higher frequencies and then the power would go down.
It is quite hard to make a power transformer suitable for a large frequency range. In a tube amplifier often the audio transformer contributes to the altered sound you get from them.
lpfthings
Sat Apr 12 2008, 01:27PM
Completely forgot about the frequency aspect.... Well i guess its just to easy to work then.
Wolfram
Sat Apr 12 2008, 02:02PM
It works with standard AC transformers. They are made for mains frequency, but they work well beyond. Of course the audio is not exactly going to be Hi-Fi, but I suppose you wouldn't expect that in an application like this. To step up the voltage to mains, you can just use a mains -> low voltage transformer hooked up with the low voltage coil to the amplifier and the mains coil to the primary of your HV transformer.
It would sound quite bad I suppose, since the spark would extinguish during the zero-crossings.
It has already been done, see towards the bottom of this page: Link2
Anders M.
Sat Apr 12 2008, 02:07PM
The arc would go out in more silent parts of the audio.
Avi
Sat Apr 12 2008, 02:52PM
actually, it'd be more like this.
1208011955 580 FT43310 Picture 7
