  • Guests: 56
bi polar primary wiring
Kristian
Sat Apr 12 2008, 12:34PM Print
Kristian Registered Member #611 Joined: Wed Mar 28 2007, 11:40PM
I have wound two identical 2" secondaries to use in a bipolar configuration on a small nst powered coil. I have the nst wired in parallel to the terry filter and the safety gap. The synchronous rotary gap is in parallel with the safety gap. The MMC is wired in series with the primaries and those are in parallel with the srg. I'm assuming that the two primaries should be parallel with each other with the inside turns connected to the MMC and the outside turn taps connected to the spark gap, like mirror image primaries. Does this sound right? Does anyone have a schematic for this configuration that they could post to clarify this wiring for me?
Coronafix
Sat Apr 12 2008, 01:48PM
You can consider the two primaries to be just one that is split in the middle, just like
considering the two secondaries as one long 1/2 wave coil rather than two 1/4 waves
connected in the middle. Does that help?
northern_lightning
Sat Apr 12 2008, 04:31PM
northern_lightning Registered Member #1348 Joined: Sun Feb 24 2008, 01:48AM
say, for example, you have a bipolar setup with two identical secondaries, each 2 inches in diameter by 8 inches tall.
when calculating their combined bipolar resonant frequency do you
a) treat the two secondaries as one large secondary with a diam. of 2" and a height of 16" and calculate the resonance based on the inductance and self capacitance for a coil of these dimensions. or
b) view the two coils as separate, calculate the inductance and self capacitance of each 2" x 8" coil (values should be just about identical), add the results for the two, and then derive the resonant frequency from these numbers?
(a) and (b) would give two completely different resonance values. and (b) cannot be derived from simply splitting the values of (a) in half. basically what i'm wondering is: should the two secondary coils be viewed as two isolated inductances in series since they are separated by distance? if not, why? i'm confused. (insert perplexed emoticon here)
Kristian
Sat Apr 12 2008, 06:17PM
Primaries diagram
This is what I was thinking for the primaries. The round thing that looks like a button is the rotary spark gap (I forgot to label it). I was thinking that I would tune each primary and secondary as individual coils.
northern lightning, my math gets a little fuzzy here. I think option b would be correct for this configuration. I'm not sure how to calculate the frequency of the primaries with the capacitor bank. I'm thinking I would just calculate the frequency for one primary / secondary and match that on the second set. I may be way off on this. I got to this point and shelved the project for weeks while I thought about it for a while. I figured I would ask if anyone here could point me in the right direction for wrapping my brain around this.
Sat Apr 12 2008, 07:23PM
Well a bipolar tesla coil has only one primary. Check this out: Link2
It has just one primary,as should be. The purpose of a bi-polar tesla coil,i figure,is to have two outputs on the secondary so you have the same output voltage but it have basically a 'hot' and a 'ground' even though neither of them are either one of them, Just make a regular tesla coil and move the primary to the middle. I could be wrong about all this but i think i am spot on.
Kristian
Sat Apr 12 2008, 08:05PM
More like this
or a much smaller version of the Gemini coils
Has Capper been around here lately? I know he has made a couple of coils like what I'm talking about.
Sat Apr 12 2008, 08:45PM
Oh..I sure feel stupid!
Coronafix
Sun Apr 13 2008, 01:16AM
Actually the setup is both primaries in parallel, one side connects to gap, the other side to the MMC.
So just swap the MMC with the spark gap in your diagram. This way the MMC is also in parallel with the primaries
but on the other side of the spark gap.
Kristian
Sun Apr 13 2008, 03:42AM
I think I got it. Primaries in parallel, anti phased. I don't see why this wouldn't work. Can anyone confirm if this is correct?
hvguy
Tue Apr 15 2008, 04:46AM
hvguy Registered Member #289 Joined: Mon Mar 06 2006, 10:45AM
Yep, It's right. Provided your secondaries are wound the same direction it will work.
